It is currently Tue Aug 12, 2025 1:40 am
PostPosted: Thu Jun 22, 2006 4:23 pm
Yep, being on vacation helps a bit, today i made myself a plexiglass template for the neck profile and used it on my neck blank to draw the outline, i then cut the blank on my bandsaw.
I cut the entry for the tenon on the top.
Routed the channel for the truss rod, check the set up made with boards and clamp everywhere, it worked well but i'm sure there is a simpler way of doing that, i'll probably start a thread just to see your setting up
To the left of the neck, there is a thick aluminum straight edge that i used to cut the straight channel, my router was leaning against it.
And finally, i cut the tenon with the table saw, lots of remeasuring to make sure the depths were acurate but it paid off, it went really smooth.
Thanks again for watching!
Sergio
PostPosted: Thu Jun 22, 2006 4:29 pm
Nice job, Serge! I really like the 5 piece neck...very well done, good sir =)
OT: Are you pretty happy w/ your Ridgid bandsaw so far?
Jordan
PostPosted: Thu Jun 22, 2006 4:57 pm
   That looks great, my friend. I too really like that 5 piece neck.    I see you have the 'bible' on your work bench there... What would we do without it?!!
PostPosted: Thu Jun 22, 2006 5:11 pm
Thanks Jordan, yes, my bandsaw does well for lutherie things, i find it big enough, of course, i'd like bigger but the cash flow is runnin' low around here, i do recommend it to anyone who wishes to buy one though.
Thanks bud, yeah, the bible is there though i'm not following it to the iota, i must be lazy when it comes to reading books, i prefer the images! Probably has somethun' to do with time spent on College and University benches!
PostPosted: Thu Jun 22, 2006 7:07 pm
[quote] Thanks again for watching! [/quote]
Great Show!
PostPosted: Thu Jun 22, 2006 11:30 pm
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Looking good Serge! I'd better get busy!
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Thu Jun 22, 2006 11:46 pm
[QUOTE=Alain Desforges]    That looks great, my friend. I too really like that 5 piece neck.    I see you have the 'bible' on your work bench there... What would we do without it?!! [/QUOTE]
WARNING!!!! The men in that book are professionals! DO NOT attempt those hair-dos at home!
PostPosted: Fri Jun 23, 2006 1:20 am
Sergio -- I'm liking the looks of that neck! Nice wood combo!
PostPosted: Fri Jun 23, 2006 1:32 am
Thanks guys!
Billy, stay tuned! More after the break!
Mark, where are you at on your build bud?
Larry, yes, especially the acrobatic section with the truss rod images, one could easily get hurt while twisting!
Thanks Anthony, hopefully, we'll be able to play it on july 29th!
PostPosted: Fri Jun 23, 2006 2:18 am
I too like the five piece neck. I optioned not to cut my tendon on the bandsaw. I couldn't get my head around the idea on how to cut it on a 5 deg so the the neck angle would be close enough to fudge with chisels and scapers. Did you just cut it on a 90 deg and add the 5 deg later?
Clinton
PostPosted: Fri Jun 23, 2006 5:38 am
Way to go, Serge. I'm going to have to try that PH, it really looks great in that neck. Good job!!
PostPosted: Fri Jun 23, 2006 9:38 am
Hey, no slacker for sure! Now we're talking!!
Keep 'em coming! Well done!
PostPosted: Fri Jun 23, 2006 3:32 pm
Looks great Serge, good to have you back and in the shop again!
PostPosted: Fri Jun 23, 2006 4:56 pm
Thanks for the encouragement guys!
Thanks Clinton, you probably mean 1.5 degree angle right? if so, you just have to use a protractor and draw your line on the side of the heel but for some reason, i did not have to do this, my angle is spot on 1.5 so maybe my fence was a little off and i was lucky!
Thanks Ron, PH has a great color for appointments, especially when your instrument is for a lady, in this case my Mom, she adores roses and it was the closest color i could find around here, i'm also thinking of inlaying a single rose somewhere on the guitar, either the headstock, the heelcap or maybe even on the top, i'll let the inspiration guide me. PH is a challenge to work with, it's brittle, splinty and hard to bend but when you have success with it, the rewards are great!
Thanks Peter, you sure know what it means to be building for a lady huh?
Thanks Hesh, i bet we were both good at the same discipline!
Thanks Mike, talking of shop, i'd really love to see a pic of you and your shop, that is if ya ain't too shy to show us your mug cowboy!
PostPosted: Fri Jun 23, 2006 5:02 pm
Serge, can you explain how I pull a picture from my "My Pictures" file and post it?
I have made a few attempts and failed. Been busy and just have not tried anymore or ask anyone.
Not shy at all, quite purdy with a nice smile! You will like my little shop, We call it the Rooster House, you will see why, if I can ever figure this posting out.
PostPosted: Fri Jun 23, 2006 5:16 pm
Ok Mike, here's how:
when you answer to a thread, at the bottom of the page, you have them buttons lined up right underneath FONT    SIZE    &nbs p;COLOUR
Right underneath COLOUR, the second one from the right, with a tree and a blue arrow will help you upload your picture from your computer to here, you might have to reduce your pics size, if so, reduce the OLF window, go to your pic file, right click on the one you want to transfer and open it with a photo-editor, the size i use is 500 X 333 pixels.
if that doesn't work, just send your pics to my e-mail address and i'll do it for you!
