Attaching the top and back http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=7991 |
Author: | Philip Perdue [ Mon Aug 14, 2006 8:05 am ] |
Post subject: | |
I was just sitting at lunch and thinking about spool clamps (what can I say) and how they are made and used. That made me wonders how spool clamps can be used to attach the top and back if the sides are inside a mold. Are spool clamps only able to be used on a rim outside a mold? What method of top and back attachment do you use? Thanks Philip |
Author: | LanceK [ Mon Aug 14, 2006 8:08 am ] |
Post subject: | |
No you can drill holes in your outside mold all the way around the body, then run your spool clamps through the holes. |
Author: | Mark Tripp [ Mon Aug 14, 2006 8:10 am ] |
Post subject: | |
Good question Phillip. Don't have an answer for you, though I'm sure someone will. I use my go-bar deck, with a caul so I don't damage the top or back. -Mark |
Author: | burbank [ Mon Aug 14, 2006 8:11 am ] |
Post subject: | |
I've seen holes drilled in the mold near the sides to allow the spool clamps to pass through. Seems like this would be a pain at glue-up time though, IMHO. I and others have used go-bars. My setup looks like this: ![]() edit: man these guys post quick! |
Author: | Mark Tripp [ Mon Aug 14, 2006 11:43 pm ] |
Post subject: | |
I do it just like Pat, 'cept I glue the back on first... -Mark |
Author: | MSpencer [ Tue Aug 15, 2006 12:43 pm ] |
Post subject: | |
Terry, where did you get those spool clamps? Mike White Oak, Texas |
Author: | Rod True [ Tue Aug 15, 2006 2:16 pm ] |
Post subject: | |
[QUOTE=burbank] I've seen holes drilled in the mold near the sides to allow the spool clamps to pass through. Seems like this would be a pain at glue-up time though, IMHO. I and others have used go-bars. My setup looks like this: ![]() edit: man these guys post quick![/QUOTE] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Author: | burbank [ Wed Aug 16, 2006 4:26 am ] |
Post subject: | |
[QUOTE=Rod True] [QUOTE=burbank] I've seen holes drilled in the mold near the sides to allow the spool clamps to pass through. Seems like this would be a pain at glue-up time though, IMHO. I and others have used go-bars. My setup looks like this: ![]() edit: man these guys post quick![/QUOTE] ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Oh, I forgot to mention. It's my combo access/sound port. Needs a little work though, seems I lost some volume. ![]() |
