Martin private tour ... long post
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=8029
Author:  Tim McKnight [ Wed Aug 16, 2006 1:22 pm ]
We had the privilege of meting the VP of Martin last fall while we were exhibiting our guitars at the IBMA show in Nashville. He spent some time with us at our booth and extended an invitation for a personal tour of the factory the next time we were in Nazareth. Well, we decided to take him up on his offer last week. We had already been through the public tour a couple of times before so he offered to show us more of the "behind the scenes" processes of the factory, that aren't part of the general public tour.
The first stop was the [incoming] wood warehouse. The warehouse was behind two locked [card reader access only] security doors. Boys and girls, I was weak in the knees to say the least just gazing around the huge building. The shear volume of wood that a factory goes through was nothing short of amazing. There were two large kilns in the corner about the size of a two stall garage. One was loaded with fingerboard and bridge blanks and we got to take a whiff inside one of them. The other was still in [computer controlled] process.
The next stop was the SECOND wood warehouse (behind another security door) where the waiting for process wood is stored. This warehouse had the same height ceilings as the first warehouse and I would guess they were 20'- 30' high. This room had rows and rows, shelf after shelf, pallet after pallet of wood that has already been dried and is normalizing to plant RH levels. All the wood was stored from the floor level to the upper shelf close to the ceiling. ROWS of Sitka, Adirondac & Carpathian, tops, backs (EIRW, Mahogany, MAdRose, Bubinga, Cherry, Walnut, Maple, BR, SE Asian) sides, neck blanks (Mahogany, cherry, laminates of various colors), yada, yada, yada...
In one corner of that warehouse is another area that is behind BARS. This is Chris' private reserve of wood. Can you say BR, mouth watering, perfectly quartered, zootalicious black ink spider webbing like you have NEVER seen. I was in total awe and I have goose bumps now just writing about it. MadRose like we USED to see, Honduran with ink, Zoot Mahoganies & Bubingas, SE Asian with ink, all with perfect and / or ultra zoot figure. I asked if Chris played or builds and I was told that he did neither but that he uses this wood for special projects that he comes up with.
The next stop was the CNC area. Necks were being machined, 12 at a time, in about a minute. A new machine, that I he was eager to show us, was a 30 TON, CNC machine that cut fret slots. The coolness of this machine is that it took a FB blank and cut the fret slots just shy of the edge of the FB so there is no need to bind the edge of the FB. How cool is that? It uses a micro rotary cutter (.023"), takes shallow cuts the length of the slot, the table indexes up for the next path a bit deeper and in about 4 passes it has cut the fret slot to the proper depth. With such a micro bit they can't hog the wood in one pass or the bit will snap. There were about a dozen blanks being cut at the same time.
Next we saw the Laser machine that cuts out tops backs and sides in about 5 seconds. The wood is vaporized by the laser and there is no wood chunks being blown out and the result is a perfectly smooth edge.
The last time we were there all of the body forms were wood. Now they are using (thier own designed) cast aluminum forms for each body. Tops and backs are glued in the same press manner as before but in a Plexiglas [heated] chamber to speed the process.
They use a LOT of jigs and fixtures so a few questions prompted a tour of their Tooling Department. This is where the Tool Makers machine all of Martin's in-house designed and built jigs and fixtures. This is a two floor department operation. Not just some cubby hole in the corner.
I was also taken in the private R&D lab. My eyes were amazed at all of the new projects they were working on. Sorry guys but my lips are sealed out of respect.
The Martin Company has a great deal of respect for the health and well being of their employees. The vast majority of jigs and fixtures were designed with ergonomics in mind for the employee. Even though they have automated many of their processes Martin still does a great deal of hand work.
Huge down draft walls and booths were seen everywhere. The last time we were there the lacquer fumes were very strong in the paint department. This has been addressed and corrected with better ventilation systems. We didn't smell any fumes at all. The vast majority of guitar bodies are now shot with robots. Speaking of robots, the bodies are also buffed by robots with huge 6 FOOT diameter buffing wheels. The area is behind Plexiglas and ventilated so there are no fumes even when buffing.
We saw the 5K Uke. That's right, a $5000.00 Uke that is 100% hand made from start to finish. Cute little all Koa buggers.
The last machine that I saw that I was greatly impressed with is their newly acquired (less than a month old) Plek Pro machine. You load a finished [unstrung guitar] into the machine and it simulates string pull on the neck and then measures each fret height and position relative to the other frets and FB. If one end of one fret is .001" higher than the other end of the fret the machine cuts the fret height perfectly from fret end to fret end. It then dresses each fret relative to the plane of the FB. In less than 5 minutes the neck frets are accurate to within .001". Try that with your fret files ;)
We saw so many other tidbits but these were just some of the high lights of the tour. I am so honored and grateful to have been given this opportunity to experience. Martin is an icon of the industry and a benchmark that we all use as a metric to gage our progress against. What is so gratifying is their willingness to openly share ideas and progress with us. So, my humble thanks to the fine people of Martin Guitar. Long live the king.
Author:  Serge Poirier [ Wed Aug 16, 2006 2:21 pm ]
WOW Tim, that visit sure was a priviledge that was offered to you, i can imagine the pallets and being in awe all the way through the visit, must have been one great visit for sure!
Author:  Dennis Leahy [ Wed Aug 16, 2006 2:41 pm ]
Thanks for the post Tim. Very cool. One company that refuses to make Martin clones!
Dennis
Author:  Dickey [ Wed Aug 16, 2006 2:48 pm ]
Thanks for the post Tim. Good to hear about your great adventure at Martin. Excellent descriptions we know you had a good time, your amazement at the zoot piles is evident, as I'm sure most of us too would be amazed.
Some day. Go Tim Go!
Author:  vpelleri [ Wed Aug 16, 2006 3:17 pm ]
Thanks for sharing the details of your trip, Tim. I can tell from your description that you had a great time. I'd love to see Chris' private zoot pile. Did they give you any free samples?
Author:  JJ Donohue [ Wed Aug 16, 2006 3:30 pm ]
Thanks for the great virtual tour, Tim.
Don't be a stranger around here...how's your golf game these days?
Author:  RussellR [ Wed Aug 16, 2006 7:09 pm ]
Thanks Tim
Chris seens to be working wonders at Martin and getting them right were they need to be.
What a great oppurtunity, as you said Long Live the King.
Author:  Kevin Gallagher [ Wed Aug 16, 2006 10:46 pm ]
Tim,
   Great post and it sounds like your visit was a fun and enlightening one. I'm sorry that we missed you while you were in the area, but I was still in no condition to be good company or host to anyone.
   Thanks for the calls and emails though...may be next time...or maybe we'll find ourselves in your neck of the woods for a visit.
Keep in touch my friend,
Kevin Gallagher/Omega GuitarsKevin Gallagher38946.3247453704
Author:  Matt Gage [ Wed Aug 16, 2006 10:58 pm ]
Long live the King!
thanks for sharing Tim.
Author:  Pwoolson [ Wed Aug 16, 2006 11:26 pm ]
Tim, sounds like a great trip. Mary had mentioned that you went but didn't go into detail about the tour itself. Sounds like you'll be in hog heaven for awile.
Author:  Michael McBroom [ Thu Aug 17, 2006 2:29 am ]
About a year ago, I was at a BBQ and a fellow brought his brand new Martin DX1 dreadnaught to the get-together. I wasn't familiar with the model at the time, but learned more about it later. When he told me it cost about five hundred bucks, I was stunned. The guitar had a fantastic sound, and played like a dream.
Proof is in the pudding. It appears that Martin has managed to automate their construction process to a very high degree without sacrificing the quality of sound and playability that is a hallmark of their guitars. I am sure, given the price point of the DX1 and based on Tim's descriptions of Martin's process, that it received only minimal human input during its construction. But you sure wouldn't know that by looking at it, playing it, or listening to it.
Best,
Michael
Author:  Sam Price [ Thu Aug 17, 2006 3:24 am ]
An amazing post. SO vividly described, it felt like I was there!!! Wow, the woodstore...
I had an experience like that once when I discovered a wood turning supplier on the Welsh Border, hidden away...he had a beautiful store full of wonderful cedar, walnut, cherry...you name it...
I might go and check him out to see if he'll prepare some billets..
I would love to visit a guitar factory one day. I am hoping to visit the Avalon and Lowden Guitar factories in N. Ireland sometime....
Author:  CarltonM [ Thu Aug 17, 2006 5:14 am ]
Thanks for the tour, Tim. Martin's door always seems to be open a little wider for hand builders, thanks to guys like Dick Boak and, of course, Chris III.
Author:  Dave Anderson [ Thu Aug 17, 2006 9:22 am ]
Thank You Tim,That was such a good discription of your tour.It sounds like an incredible place.Man,Wouldn't we all love to see Chris' stash of super-Zoot.
Author:  rich altieri [ Thu Aug 17, 2006 11:52 am ]
Great description of the behind the scenes look. Hope I can have that honor some day. What a great experience
