Best Router
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=8532
Author:  Dave-SKG [ Tue Sep 19, 2006 12:18 pm ]
Can anyone tell me the advantages of having a variable speed router vs. fixed. I am looking at the P.C. 7518 and 7519. Both are 31/2hp why or on which woods would I use a slower speed? TIA
Author:  Louis Freilicher [ Tue Sep 19, 2006 1:28 pm ]
I always use mine set for fast with the LMI pattern routing but in a
router table. The slower speeds would be needed for larger diameter
molding and raised panel bits. A larger bit diameter means that the
bit is moving faster at the cutting edge thus the need for speed
reduction at the motor. Hope this helps.
Louis
Author:  crazymanmichael [ Tue Sep 19, 2006 1:53 pm ]
slower speed also required when doing aluminium, plastics, etc.
Author:  Dave-SKG [ Wed Sep 20, 2006 12:18 am ]
Thanks guys!
Author:  Louis Freilicher [ Wed Sep 20, 2006 9:58 am ]
You're welcome Dave. BTW I love my PC7518. It's mounted in a
home build router table and it has worked like a champ.
Louis
Author:  npalen [ Wed Sep 20, 2006 12:00 pm ]
Variable speed is for when the kids are sleeping.
Nelson
Author:  Phil Marino [ Wed Sep 20, 2006 3:08 pm ]
One reason for running a router slower is to reduce burning.
Some woods - cherry, for example - burn easily if you move the router too slowly when making a cut. If you run the router bit slower, you can move the router slower also, without burning the wood.
Phil
