Stew Mac Buffer troubles
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=8819
Author:  Louis Freilicher [ Thu Oct 12, 2006 3:11 pm ]
My Stew Mac buffer seems to have a warble on one side. The left
bearing has a knock making that wheel less than smooth to use. The
right side is tight and works fine.
It looks like there is an adjustment collar of some sort on the inside
of the arbor, allen head screw etc. But I haven't had a chance to take
it apart yet.
Anyone have any similar issues? Or a fix idea.
LouisLouis405239003.0086574074
Author:  Kelby [ Thu Oct 12, 2006 4:31 pm ]
Louis, is this a new buffer?
I found that I had to have the nuts on the right and the left side spaced the same number of threads from the end to ensure it spun in balance; I didn't have any problem with the bearings.
Author:  Mario [ Thu Oct 12, 2006 4:36 pm ]
Read where I explained how to balance the buffs, also. About a month ago, so it should still be on the board.
Author:  Brock Poling [ Fri Oct 13, 2006 12:39 am ]
[QUOTE=Mario] Read where I explained how to balance the buffs, also. About a month ago, so it should still be on the board.
You can find that discussion HERE
Author:  Louis Freilicher [ Fri Oct 13, 2006 9:37 am ]
Thanks for all the info. I'll have a closer look at it this weekend.
Louis
Author:  Louis Freilicher [ Fri Oct 13, 2006 2:56 pm ]
I've beefed up my stand, which helped a lot, and I'm working on
balancing the wheels using Mario's guidelines. She's been in and
out; when she's out she wobbles like crazy. It's been easier to tell
when the balance is off.   When it's close I keep thinking I can make
it better and then I make it worse. I’m going to keep at it until she's
right on.
Thanks for the help all.
Cheers,
     Louis
