sound port pictures http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=8841 |
Author: | Terry Stowell [ Fri Oct 13, 2006 11:57 am ] |
Post subject: | |
anyone have sound port pix or construction tips to post? Buscarino below ![]() |
Author: | peterm [ Fri Oct 13, 2006 12:17 pm ] |
Post subject: | |
Here's a couple I made. One is in the works and the other was on my wife's mother's day present! ![]() ![]() ![]() |
Author: | LuthierSupplier [ Fri Oct 13, 2006 2:09 pm ] |
Post subject: | |
Here's my last one on the irish bouzouki Those are all great looking sound ports! Tracy |
Author: | Graham Steward [ Sat Oct 14, 2006 12:49 am ] |
Post subject: | |
Do you guys cut the sound port before or after bending the side? I would imagine that cutting it after the bending would make it a lot easier to get in the right spot, but it seems like the bend in the bout would make it difficult to cut that way. Thanks! |
Author: | SniderMike [ Sat Oct 14, 2006 1:29 am ] |
Post subject: | |
![]() I did this one on my last SS. I cut it with a dremel w/ Stew Mac router base, after bending, but before attaching back and top. I cleaned it up with needle files and a jeweler's saw. Mike |
Author: | LuthierSupplier [ Sat Oct 14, 2006 2:07 am ] |
Post subject: | |
Graham, I bend the sides first, then glue in a 2 layer veneer of black/white using foam and clamps so it conforms to the side. Then process the sides as usual with kerfing, then tape your picture in place and use a dremel to cut out the large areas. I then clean up with needle files to file down to the line. Hope that helps. Tracy |
Author: | Serge Poirier [ Sat Oct 14, 2006 3:35 am ] |
Post subject: | |
WOW, great thread Terry, thanks! Nice soundports guys, keep them pics coming and thanks for the input! ![]() ![]() ![]() |
Author: | Graham Steward [ Sat Oct 14, 2006 3:39 am ] |
Post subject: | |
Thanks for the descriptions guys. That really helps. I think on my next build I will give that a try. ![]() |
