HHG Clamping Time(s) http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=9181 |
Author: | Alain Desforges [ Mon Nov 06, 2006 1:13 am ] |
Post subject: | |
Hesh, I think you can safely start carving away after about 30 minutes. However, I always like to leave things for at least an hour. I actually used to wait over-night, but that's overkill... Hope this helps... Cheers, Al |
Author: | JJ Donohue [ Mon Nov 06, 2006 1:17 am ] |
Post subject: | |
4 hours...unless I only play 9 holes. Then it's 2 hours ![]() |
Author: | Mario [ Mon Nov 06, 2006 2:12 am ] |
Post subject: | |
2-4 hrs. 24 for a bridge. |
Author: | Marc [ Mon Nov 06, 2006 3:40 am ] |
Post subject: | |
I was able to complete a soundboard on Saturday because HHG is so quick, it's workable in 2-4 hours in most cases. Resaw-Thickness-Joint *Glue Joint Plates HHG 3 hour* Thickness-Cut Rosette Channel *Glue in Rosette HHG Glue 3 hour* Scape Flush-Drill Sound Hole-Final Contour Thickness ![]() ![]() |
Author: | Serge Poirier [ Mon Nov 06, 2006 4:41 am ] |
Post subject: | |
Overnight is a great thing because you're going to sleep and can't mess with it even if overkill, i love the wisdom behind it so i almost always do my glue ups at night. ![]() |
Author: | Alan Carruth [ Mon Nov 06, 2006 4:49 am ] |
Post subject: | |
I was told to clamp for two hours, and avoid stress for at least eight. OTOH, I was showing a friend how to do a 'rub' joint once, using a couple of pieces of leftover bracing stock. I rubbed them together and put them on the bench for 15 minutes. Then I clamped one in the vice and whacked the other with a hammer. I got 100% wood shear. The stuff is amazing.... |
Author: | npalen [ Tue Nov 07, 2006 1:50 am ] |
Post subject: | |
Perhaps we should have Lance declare "holes" as the official time measurement increment for the OLF. ![]() How long did it take you to do the binding? Oh, about 50 holes. |
Author: | Serge Poirier [ Tue Nov 07, 2006 8:21 am ] |
Post subject: | |
My father in law does that when mowing the grass, he says it's a bout 3 beers and does it with a tractor! ![]() |
Author: | Rod True [ Tue Nov 07, 2006 8:46 am ] |
Post subject: | |
That would be a very small yard he's got there than Hey Serge? What 4 or 5 passes ![]() |
Author: | Serge Poirier [ Wed Nov 08, 2006 4:39 am ] |
Post subject: | |
Yes, it is small, i guess he drinks fast! ![]() |
