bandsaw fix?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10102&t=9628
Author:  Jim Kirby [ Sat Dec 02, 2006 12:43 pm ]
I was speculating that my bandsaw tension spring had died here recently (Delta 14"), and after some reinforcing backup from Todd Stock, I got a replacement Carter spring from Woodcraft. Has anyone had a problem with these springs being too short? The spring doesn't take up tension until the tension indicator is already up past the 1/8" mark.
This doesn't mean that the spring isn't able to eventually tension the blade, but it sure is out of calibration with the tension marks on the machine. jtkirby39053.8637731482
Author:  Jim Kirby [ Sat Dec 02, 2006 1:47 pm ]
Todd - Thanks for that clue, that makes sense.
JK
Author:  nathan c [ Sun Dec 03, 2006 2:51 am ]
Jim, I was recently looking for guide bearings for my Rockwell 10". There is a website that is usually called "Servicenet" by woodworkers (link) that has parts for the most popular tool brands. I posted my question about servicenet to a woodworking forum here
and got some good responses about servicenet. I plan on ordering soon.
Oh and BTW they have manuals as well.nathan c39054.4527430556
Author:  JJ Donohue [ Sun Dec 03, 2006 5:05 am ]
Todd...I have some questions about a used 14" Delta (with riser block) that I bought some months ago.
The tension indicator (red mark) is not visible and I've been tensioning by feel... once the blade produces a ringing tone when snapped, I stop tightening. I know that this could be problematic and wanted to get some advice.
Where "should" the red mark be located? Right now, the 1/8" mark aligns about midway along height of the nut at the bottom of the yellow spring. This is with a 1/2" wide x .023" kerf blade. I'd be surprised if I stumbled at the proper tension but wanted to get your expert opinions and guidance. TIA.
Author:  alambert [ Mon Dec 04, 2006 3:48 am ]
Newbie question. What exactly does "resaw" mean? What about barrelling?
Author:  JJ Donohue [ Mon Dec 04, 2006 5:04 am ]
Thanks, Todd. Great info! Just what I needed.
Author:  BBailey [ Mon Dec 04, 2006 6:19 am ]
Todd
Any experience or opinions on the larger Grizzly bandsaws in the 18 or 20 inch range. I'm looking to replace my worn out 14" import with something a little more heavy duty to do some resaw work.
Bob
Author:  alambert [ Mon Dec 04, 2006 7:16 am ]
[QUOTE=ToddStock] Good questions...
Resawing is just that - taking a relatively thick board and cutting it into thinner slices. Imagine the wood is 36" long, 8" wide, and 3/4" thick. With careful sawing, we can get four pieces that are still 36" x 8", but now each piece is only .130-.140 or so thick... perfect to use for backs and sides after a bit of sanding or planing. In the pic below, each larger piece of stock is cut into these thinner pieces - a board that started out 12' long x 10" wide x 5/4 thick wound up yielding 12 side sets and 9 back sets - about $15/set for some lightly figured bubinga from a local Woodraft.
Barrelling occurs when resawing with a blade that is not properly tracked or tensioned...the blade describes a curved path down through the wood that can look a bit like the shape of a barrel. Not good - wastes wood and is tough on the blade as well...tension and proper tracking takes care of the issue.
Thank you.
