It is currently Tue Aug 19, 2025 1:51 pm
PostPosted: Wed Dec 27, 2006 2:24 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Zip/Postal Code: 98506
Hey Gang:
I have a set of these Ibanez files:
I don't use them for nut work anymore, as I have a complete set of the StewMac files. I was thinking it would be handy to have a couple of these cut lengthwise and ground down to make myself tools to clean up my slots at the bridge-pin holes. I cut the slots with a jig saw, but want to give them a more refined look.
I'm not quite sure how to go about cutting these lengthwise. Any suggestions?
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Dec 27, 2006 2:50 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Thanks Todd!
Hadn't thought about selling them and buying something made for this purpose - I'll look into that.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Dec 27, 2006 3:46 am
I used dremel cutoff wheels to slice then down the middle, then cleaned
them up on a bench grinder. I bought the Stew Mac joint edge files for
this because they didn't have the tapered handle and I was able to get two
sets out of them. As Todd mentioned the trick is keeping them cool.
I originally made these as a low profile slotting file for resonator guitars,
so that you can set the bridge height without removing the cover plate. It
was years later before I thought about using them for cleaning up slots at
the bridge pin holes.
I really prefer the joint edge file for nut slots over the double edge
StewMac style nut files. I actually retired my old set of those in favor of a
set I compiled of Grobet, Ibanez, StewMac and other joint round edge
files. I also think if you're making these just for bridge pin hole slots, you
may be better off selling them and buying a decent needle file set.
PostPosted: Wed Dec 27, 2006 4:20 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Hi David:
Thanks. Could you explain what a "joint edge file" is?
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
PostPosted: Wed Dec 27, 2006 4:42 am
Those files you have in the picture above are joint edge files. They're not
made specifically for lutherie, and are made by a number of file makers for
jewelers and other trades. Grobet is usually the prefered, for good reason.
Grobet Joint Round Edge Files
PostPosted: Wed Dec 27, 2006 4:45 am
First name: Mark
Last Name: Tripp
City: Olympia
State: Washington
Excellent.
Thanks for the info.
-Mark
Pullman, WA
trippguitars.com
OR
Find me on Facebook
