Weissenborn setup question or something
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10104&t=22662
Author:  troymarcio [ Sun Jun 07, 2009 9:03 pm ]
Post subject:  Weissenborn setup question or something
I'm having problems with the last few lap steel guitars I've built with volume on the 6th string. I am hoping that it's with my setup and not something with the bracing or top/back thickness or various other building issues that can effect the sound.
I try to set the string height at the nut between 1/2" - 3/8" from the fingerboard and make sure that the string height at the bridge is higher than the nut height. Does this seem okay and could this have an effect on not getting enough volume? The interesting thing is that the 1-5 strings sound fine but the 6th string seems "dead".
Any feedback would be great.
Author:  LouisianaGrey [ Mon Jun 08, 2009 2:17 am ]
Post subject:  Re: Weissenborn setup question or something
The Weissenborn builders all hang out on the main forum so it would be best to ask the question there. Your string height sounds OK to me, though. Could it be the nut slot that's the problem? What strings are you using?
