It is currently Mon Sep 15, 2025 11:01 am
 Post subject: Rhino Command Question
PostPosted: Sun Apr 06, 2008 7:13 am
What is the Rhino command to have dimensions displayed in fractions (as opposed to decimals). For example when I use the Dimension command it shows the body length as 19.13" whereas I'd like it to display 19-1/8".
Sorry for the dumb question.
PostPosted: Sun Apr 06, 2008 8:38 am
Anthony, if it's anything like turbocad, I get at it through "properties" then "units / tolerences". Might be something similar.
Milton, ON
PostPosted: Sun Apr 06, 2008 10:39 am
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
go to tools>>options, then click on Units under the Document Properties heading, and then click off on "fractional" in the resulting dialog box..
http://www.PeakeGuitars.com
PostPosted: Sun Apr 06, 2008 4:11 pm
I did just that and it is still displaying Dimension measures in decimal places.
PostPosted: Sun Apr 06, 2008 5:27 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
changing the settings in the options should result in changes in previously created dimensions...might be a bug or something?
Mine (version 3.0) works as described...
PostPosted: Sun Apr 06, 2008 6:13 pm
Dimensions menu, then dimension properties.
PostPosted: Sun Apr 06, 2008 6:51 pm
Not only is it not showing a fraction, it is not showing the correct decimal equivalent.
Is the software rounding up as to show only 2 decimal places in stead of three or maybe the software is not going to show a weird fraction? How was the dimension entered in the first place?
Rich S
"The inconvenience of poor quality will linger long after the thrill of a bargain has been forgotten"
PostPosted: Sun Apr 06, 2008 9:17 pm
Drats...still not working. Any chance I could email one of you the file to see if it works on your version. I am using Rhino 4.0. (Please PM me your email address).
Anthony
PostPosted: Sun Apr 06, 2008 9:45 pm
First name: Nelson
Last Name: Palen
Hey Anthony
Are you sure that you're in inches rather than millimeters? The Startup Template allows this type of setting to be changed.
There, I've told you everything I know about Rhino--and it's probably wrong.
Nelson
PostPosted: Mon Apr 07, 2008 10:12 am
First name: Nelson
Last Name: Palen
I'm not able to display fractional inches in 4.0 either.
PostPosted: Mon Apr 07, 2008 3:13 pm
Nelson, this is sounding like a bug idunno I have been religiously downloading all of the updates as well. Might be time to contact the folks at Rhino.
PostPosted: Mon Apr 07, 2008 5:38 pm
Last Name: Watkins
City: Lake Zurich
State: IL
Learn your decimals, slacker! :P
Good to see you're still playing with it, AZ!
John Watkins
CNC Guitar Parts
PostPosted: Mon Apr 07, 2008 11:31 pm
I should learn my decimal places....maybe it is time to finally switch to metric like the rest of Canada :lol:
Hey John nice to see you checking in!
Thanks Nelson -- either both of our programs have a bug....or there is something wrong with version 4.0. I will try and get hold of Robert McNeil and see if there is a fix. When did you get Rhino? Good to know you have it so I can stop converting files I send to DXF...etc.
PostPosted: Tue Apr 08, 2008 9:53 am
Hey Anthony
I downloaded the evaluation version of 4.0 last week. Can't let you guys get ahead of me, ya know.
Actually, I've played with Rhino in the past. It's a neat package.
Metric, is that some kind of measurement system? laughing6-hehe
Best regards.
PostPosted: Tue Apr 08, 2008 8:19 pm
I can only guess the "Guest" above is that wise acre Nelson. I got a command fix from the folks at Robert McNeel. Here it goes:
Go to “Dimension” pull down, select “Dimension Properties”, select “Dimensions” and and where you see “Default” on the right hand of the screen, select “New”. Back under the “Dimension” folder you will see the new name, click on it and edit it.
When you edit you will see under “Number Format”, three buttons starting with: “Decimal”, “Fractional” and “Feet & Inches”. If you select “Fractional” for example, you can specify the level of “Precision”, i.e. 1 ¼, 1 1/16, 1 1/32 and so on.
Then click on OK and you are go to go.
