It is currently Tue Sep 16, 2025 10:30 am
PostPosted: Fri Oct 07, 2011 2:52 pm
If you take your time with the NURBS!
(Now I need to model the neck, and add binding etc...)
-CyborgCNC
http://www.cncguitar.com
https://www.facebook.com/CncGuitar
PostPosted: Sat Oct 08, 2011 9:51 pm
First name: Stuart
Last Name: Gort
How did you go about generating the top surface, C?
StuMusic
PostPosted: Sun Oct 09, 2011 8:01 pm
I used a plan i bought from stewmac, and used that as a reference to create my nurbs, paying close attention to curvuture. The top and bottom are 4 surfaces in total, because the cross sections need to be specific through out. So both the top and bottom have a top surface and a bottom surface. Simply thickening will not work in this case. I hope i am making sense.
I then used bounding surfaces, planar surfaces, and fill surfaces to drape surfaces over the above mentioned geometry. Used proper relations throughout.
Then, i used a ruled surface around the perimeters, stitched the whole thing together, and formed the solid...
:D
-CyborgCNC
