Will a laser cutter cut pearl?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10106&t=19308
Author:  DanielC [ Fri Oct 24, 2008 12:30 pm ]
Post subject:  Will a laser cutter cut pearl?
Will something like an epilog laser machine cut regular thin pearl for inlay? If not what is the best small cnc machine for cutting pearl for inlaying?, perferably one that is enclosed. thanks
Author:  Michael Dale Payne [ Fri Oct 24, 2008 1:07 pm ]
Post subject:  Re: Will a laser cutter cut pearl?
It will cut it but it burns the edges and causes it to powder about 1/32-3/64 of an inch at the cut edge so for precise edge cutting no Use water jet, CNC or good old jewelers saw.
Author:  Bob Garrish [ Fri Oct 24, 2008 1:25 pm ]
Depends on what you mean by 'best'. If price is the determining factor, the K2CNC stuff can be adapted to your needs.
Author:  John Watkins [ Tue Oct 28, 2008 3:13 pm ]
Hard to beat the Haas Office Mill for that kind of work. It'll fit through a standard 36" doorway, has a toolchanger, coolant pump, comes standard with a 50,000 rpm spindle, and is dirt cheap (relatively speaking).
