It is currently Sun Sep 14, 2025 3:21 pm
PostPosted: Tue May 26, 2009 12:15 pm
First name: Nelson
Last Name: Palen
Can you guys recommend a good source for these?
I'm looking for 1/8", 1/4", 3/8" and 1/2" and see quite a range of prices leading me to believe that some of them are inferior.
Ebay shows several different sets of metric and "imperial" but the price, which figures as low as $5.00 each collet is suspect.
I've seen prices for individual collets as high as $70 ea.
Nelson
PostPosted: Tue May 26, 2009 2:47 pm
I bought a set of cheap ER25 collets and some of them had a terrible runout. Then I changed to Rego-Fix collets from Switzerland. They are expensive, but I am sure they will last a long time. Mine are standard precision, but they have them in high precision (extremely low TIR, below 5 um). The difference can even be seen: my original collets had a matt surface, these others shine like mirrors.
PostPosted: Tue May 26, 2009 3:33 pm
First name: Nelson
Last Name: Palen
Sounds like they were vapor blasted or something to make them look pretty (matt surface) but not precision ground?
Runout is my main concern as I'm investing in a spindle that's supposed to be within .0006" TIR.
PostPosted: Tue May 26, 2009 10:00 pm
First name: kevin
Last Name: waldron
City: Bell Buckle
Zip/Postal Code: 37020
http://www.use-enco.com/CGI/INSRIT?PART ... O=22538163
Try these guys. I have always had good result with there products.
Kevin Waldron
PostPosted: Wed May 27, 2009 4:26 am
Standard TIR in most collets is 15 um (0.0006"). Some of my cheap collets measured more than twice that value. Standard precision in Rego-Fix collets is 10 um, and high precision collets are below 5 um (0.0002"). Rego-Fix were the inventors of ER collets and they must be the best around, but perhaps you may find cheaper alternatives.
PostPosted: Wed May 27, 2009 10:44 am
Last Name: Garrish
I don't know where he gets them, but I pay $20 a collet from my tooling guy. He supplies all the aerospace shops, etc, around here so he only sells top quality stuff. So I know that you can get top-grade ones for $20 at most :)
What's with the quotes around 'imperial'?
Bob Garrish
PostPosted: Wed May 27, 2009 1:07 pm
First name: Nelson
Last Name: Palen
"""What's with the quotes around "imperial"?"""
Good question, Bob. I never know for sure what to call it, guess I'm used to "inch system" actually. :)
http://www.france-property-and-information.com/imperial-system-and-history.htm
PostPosted: Mon Jun 08, 2009 8:00 pm
Last Name: Lembo
Nelson,
I've had good luck with collets from US Shop Tools.
Get their ultra precision (UP) collets - .0002" TIR
ER-20's are $15 each.
http://www.usshoptools.com
Anthony
Anthony J. Lembo
Lembo Custom Guitars - www.Lemboguitars.com
