It is currently Sun Sep 14, 2025 12:49 pm
 Post subject: Inlays done on my Techno
PostPosted: Sat Dec 05, 2009 12:01 pm
Last Name: Bordeaux
City: Massena
State: New York
Zip/Postal Code: 13662
Hi Guys,
Thought I would share a few inlays done recently on my cnc...
Comments welcome, I've got a lot to learn!
Of course the butterfly was routed by hand, and the tattoo image wasn't complete when the image was taken, but you get the idea....
Paul
Paul Bordeaux
http://www.bordeauxinlay.com
PostPosted: Sat Dec 05, 2009 2:03 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
Zip/Postal Code: 21032
Looks great! I bet you'll be routing by hand less and less...! [:Y:]
http://www.PeakeGuitars.com
PostPosted: Sat Dec 05, 2009 3:53 pm
Last Name: Bordeaux
City: Massena
State: New York
The strange thing is how addictive it becomes to get a design to cut "right". In the interest of learning, I have done some client inlays in 4-6 hours whereas hand cutting would have taken 1 hour or less, although it's usually on the small stuff.
It is cool to have a standard pattern being cut in one room while I hand cut in the other!
Paul Bordeaux
PostPosted: Sun Dec 06, 2009 5:32 pm
Nice work Paul. What diameter bit, depth of pass and feed speeds did you use?
tim...
PostPosted: Mon Dec 07, 2009 11:23 am
Nice work.
Another challenge is how you lay out your pearl blanks and get them into your CAD program. I've been gluing them to an mdf spoil board, taking a photo with a 6" rule for reference and importing that into Rhino. The last set had some scaling errors due to the length of the spoil board in comparison to the rule. From now on, I'm going to just measure the length of the spoil board and use that to scale.
If anyone has a better way to do this I'd like to hear it.
PostPosted: Mon Dec 07, 2009 12:53 pm
Last Name: Bordeaux
City: Massena
State: New York
.0156 bit from precisebits, .013/ pass @ 7.5ips.
I have gotten into the good habit of checking each bit for runout at every tool change, which helped improve cutter life and quality of cuts.
Paul Bordeaux
PostPosted: Mon Dec 07, 2009 2:18 pm
Last Name: Garrish
IPM...unless you've got a -really- nice spindle ( 1.8million RPM or so :) )
Bob Garrish
PostPosted: Mon Dec 07, 2009 3:14 pm
Last Name: Bordeaux
City: Massena
State: New York
Umm.... No, we work really fast here in upstate NY... wow7-eyes
You're right, I meant to say we type really fast...
Paul Bordeaux
PostPosted: Mon Dec 07, 2009 4:16 pm
First name: Trevor
Last Name: Lewis
City: Crownsville
I break multi-piece inlays into separate blocks and draw them on sketches of the shell blanks.
Here's a blue marlin inlay I did recently with white and black mother of pearl in Indian rosewood...as well as a few screenshots to show the CAD/CAM process:
and here's after inlay and a little sanding:
I cut the shell and the inlay cavity using my K2. I offset about .004" per side (to the outside) on the cavity cuts and only had to do minimal hand fitting to get everything in there. On single piece inlays I can get away with a little less gap. I used a .031" end mill at 25,000 RPM and about 2 or 3 ipm on both the shell and the rosewood. My K2 uses a porter cable router as a spindle and the runout on these isn't as well controlled as a true spindle...so I run on the slow side. All in all though, the thing works really well and sure beats the heck out of a jeweler's saw!
Trev
PostPosted: Sat Mar 13, 2010 2:51 am
First name: Stuart
Last Name: Gort
Those feed rates are a little surprising. These inlays (or at least the finshed edges) are cut with a .030" two flute endmill at 4000 rpm and 20 ipm. I step down about .020" as I go depending on the type of wood.
The trick I use is to first define the edge by using a ball mill and getting more aggressive after that.
Check it out.....
Using a contour path.......if you take an .0625" diameter ball and program your first cut to be a -.010" depth, then offset the cut by -.0083" the ball will cut to a -.010" depth with the edge placed right on your programmed contour line. This establishes that edge regardless of the grain direction. Every subsequent depth can be made much more agressively without much chance of a rip.
StuMusic
PostPosted: Sun Mar 14, 2010 8:38 am
Z,
Inoticed tuner buttons in the top picture. Tell me a bit about your process to cut buttons please.
tim...
PostPosted: Tue Mar 16, 2010 2:37 am
First name: Stuart
Last Name: Gort
Tim McKnight wrote:
Z,
Hehe.....you WOULD ask. It's the most fixture intensive thing I've done yet.
I'm in the middle of making tooling that allows for multiple sets to be made during an operation. The first time I did it I just made one at a time - while I was goofing around with cutting wood. Technically....tuning knobs were the first parts I ever made from wood.
I'll get pic's up when I'm done with these tools next week. That will go a long ways to explain this process. For now, I've done the first op on about 25 sets of knobs. I've made these in maple, toasted maple, purple heart, paduck, wenge, and bloodwood. The cycle time will be about an hour per set which I will shorten some but the process now guarantees not to rip anything. These knobs are truly nifty.
Operation #1 starts with a stick of bloodwood - 1" x 1" x 8" (long grain) out of which I cut six knobs. I cut one of the flat sides with a surfacing operation and the outside profile is cut with a contouring operation down to below the lower part plane. This contouring op follows the principals laid out on the post above. I start with a surfacing op, then a shallow 3D contour cut with a ball to establish the profile edge without ripping, then a stepped down 3d contour with a ball to finish the profile down further, then swich to a flat endmill to finish the base. The six parts remain connected on a .25" base. I'm trying to keep the continuity of the grain intact and make these in matched sets.
Operation #2 requires a tool that holds two sets of these knobs (12 knobs) in two rows. The fixture allows clamping pressure to be independently applied to each knob so they hold in place as the machine cuts them apart. On this op the second side is sculpted with a surfacing operation and the basic shape is finished. The operation more or less follows the concept above...the deft use of ballmills to define the profile edge in order to guarantee no rip out.
Operation #3 requires a tool that holds two sets of the knobs on edge so that a cavity can be milled out of the bottom to constrain the square pole of the machine head. This cavity is oversized so that it can be filled with epoxy and then later milled to fit the square pole after the epoxy cures. The effort here is to eliminate the possibility of cracking over time as the machine head is used. The epoxy will stabilize the wood and be far less prone to crack than the wood itself.
Operation #4 requires a tool that holds 12 knobs on their edges in order to countersink and drill the screw hole that holds the knob onto the peg shaft.
I'll try to get nice photos along the way to illustrate this.
StuMusic
