Solidworks is a Pretty dang good surface modeller! http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10106&t=33804 |
Author: | cyborgcnc [ Fri Oct 07, 2011 2:52 pm ] |
Post subject: | Solidworks is a Pretty dang good surface modeller! |
If you take your time with the NURBS! ![]() (Now I need to model the neck, and add binding etc...) |
Author: | Stuart Gort [ Sat Oct 08, 2011 9:51 pm ] |
Post subject: | Re: Solidworks is a Pretty dang good surface modeller! |
How did you go about generating the top surface, C? |
Author: | cyborgcnc [ Sun Oct 09, 2011 8:01 pm ] |
I used a plan i bought from stewmac, and used that as a reference to create my nurbs, paying close attention to curvuture. The top and bottom are 4 surfaces in total, because the cross sections need to be specific through out. So both the top and bottom have a top surface and a bottom surface. Simply thickening will not work in this case. I hope i am making sense. I then used bounding surfaces, planar surfaces, and fill surfaces to drape surfaces over the above mentioned geometry. Used proper relations throughout. Then, i used a ruled surface around the perimeters, stitched the whole thing together, and formed the solid... ![]() |
