It is currently Sat Sep 13, 2025 1:46 pm
PostPosted: Sat Dec 31, 2011 3:24 pm
I just build a dead simple hand held spindle sander, to help me in sanding the sides of an Archtop Guitar I am building...
Dead simple, and very effective....all for about $7.00 Bucks, as compared to $80.00 from some folks who sell them..
:D
-CyborgCNC
http://www.cncguitar.com
https://www.facebook.com/CncGuitar
PostPosted: Sat Dec 31, 2011 3:55 pm
City: chicagoland
State: illinois
sanding drums get pretty hot from friction. watch out the PVC doesn't melt/deform
PostPosted: Sat Dec 31, 2011 4:00 pm
First name: Jim
Last Name: Hansen
Nice handywork there! And well done on the video!
Question though. Wouldn't it be better if the sanding 'drum' was a little bigger? say 3" or so?
And when can I order mine ? :p
Jim Hansen
PostPosted: Sat Dec 31, 2011 4:09 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Thanks for sharing!! That is a really nice tool, and at that price, you can make several so that you can have different grits. [:Y:]
Alex
PostPosted: Sat Dec 31, 2011 4:47 pm
Thanks....Yeap..hence the reason to leave the handle free, so that you can quickly and easily change the grits/drums as you need them...
I have not sanded for extended periods of time, and so far, the PVC has not deformed or melted...might be an interesting test to see however at what point that might happen for laughs and giggles...one could also use metal water pipe, electrical conduit..etc..you get the idea.
Thanks all..hope you find it useful!
-CyborgCNC
PostPosted: Sat Dec 31, 2011 5:46 pm
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I like it,. simple and cheap two of my favorite words
Fred
Fred Tellier
PostPosted: Wed Jan 04, 2012 12:21 pm
I love that idea and after reading the comments - I thought of an interesting way to improve it.
Most spindle sanders have rubber sanding drums in various sizes that aren't too expensive.
Taking your setup but switching out the PVC for something like this: http://www.ereplacementparts.com/drum-s ... 61662.html
you get sizes that match up with available sanding drum sizes.
Use allthread as your main shaft and you can now add washers to expand the drum to hold the drum tight.
I'll have to give that a try!
PostPosted: Wed Jan 04, 2012 1:26 pm
First name: Fred
Last Name: Tellier
City: Windsor
Good idea Andy but we would need a 6" rubber drum, that one is too short.
Fred Tellier
PostPosted: Wed Jan 04, 2012 4:58 pm
First name: Jim
Last Name: Hansen
Here is a thread Chris Paulick posted with take on this using a Rolling Pin.
viewtopic.php?f=10117&t=25191
Jim Hansen
PostPosted: Thu Jan 05, 2012 9:49 am
You could always butt two of them together.
PostPosted: Fri Jan 06, 2012 3:05 pm
Fred
In the custom guitar world, we like to use inexpensive rather than cheap :D
PostPosted: Sun Feb 12, 2012 4:24 pm
First name: Big
Last Name: Jim
6" ones are / should be available !
PostPosted: Sat Aug 04, 2012 3:28 pm
The thing is that if it isn't perfectly centered it will virbrate or bounce and not run true. If the bolt is bent some it will show up also. So making the end plugs isn't all that easy without a CNC as you might think unless you have a lathe or some other jig. You could turn the plugs an center drill them also. Also being and electrician I can tell you PVC conduit isn't always true so choose your conduit carefully. There are many ways to skin the cat as they say. This is one way forsure.
Also keep in mind that it isn't the cost of the material that prices a tool but the time involved in making it and the cost of tools needed to make the parts also.
I can tell you that mine probably only cost $10 in material too. The rest is in time spent making it and time spent in getting the material and even shipping it.
PostPosted: Thu Aug 16, 2012 8:18 pm
Last Name: Steele
City: Wilson
Zip/Postal Code: 14172
Very nice. I was just working on something along these lines the other day and was not 100% happy with the results.
Think I will give this one a try!
Thanks a bunch for sharing.
PostPosted: Thu Aug 16, 2012 11:16 pm
Clever. I like it.
PostPosted: Thu Aug 16, 2012 11:39 pm
First name: Ringo
lol, I tried making one of these once. It seemed such a great idea at the time and a real no-brainer considering what the ones from Grizzly or whoever makes them cost....
Now I have two of the 'overpriced' machined aluminum ones in different sizes. They were worth every penny.
