Bevel / ribrest tutorial http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10117&t=15994 |
Author: | James Ringelspaugh [ Tue Feb 19, 2008 7:22 pm ] |
Post subject: | Bevel / ribrest tutorial |
I just completed an armrest bevel and rib rest and thought I would share my methods. Surely there are other ways to do this; this is what worked for me. Hopefully someone out there will find it useful. Also please note that I am not the best writer so please ask if anything is unclear. I have been reluctant to do a bevel because I couldn't quite wrap my head around how to route the purfling channels on the sides without doing a bunch of hand work. Using .030" wide purfling this was not a task I looked forward to. Then one day it clicked that I could make a template that I could clamp to the sides to act as a guide for a router. I did a dry run on a mock-up body and decided it was good enough to attempt on a real guitar. First off I made the side template, which is made of two pieces of mahogany bent in the side bender and then laminated together on a mold in a vacuum bag. The template actually sits atop the actual sides on the mold. I laminate my sides using vacuum as well; this makes everything nice and stiff and everything fits together quite well which is absolutely key. Here is the side template being glued up: ![]() Next up I added an extra strip of lining to the sides where the bevel and ribrest would be. I just bent a couple extras when I bent the linings in the first place. ![]() ![]() Once the top/back were attached, I dug right in and rough cut the bevel with chisels and a rasp, going a little deeper than the final bevel to make room for a veneer overlay which will match the bindings. ![]() Once roughed out, I rubbed a piece of paper on the bevel to get a flat representation of the 3-D shape of the overlay (it helps to have dirty hands for this job): ![]() Next I transferred the shape to my veneer and cut it with scissors. I put tape over the cut line for support to keep the veneer from splitting down the grain. Ask me how I know to do that... ![]() ![]() Next I glued the overlay, taped it on, and cleaned it up: ![]() ![]() Next I routed the binding and purfling channel for the rest of the guitar as if there was no bevel there. Sorry I didn't take a picture of that. Next comes the heart of the system. I clamp on the templates as best as I can and route the purfling channels. I used a dremel with a 1/32" spiral bit, using the shank to register against the template. You have to keep the tool moving at a reasonable speed or you will burn the template. On the dry run I used a laminate trimmer with a guide which should also work if you're concerned about using the bit shank as a bearing. I was really wanting a Cochran plunge base for this operation! ![]() ![]() ![]() For the middle of the ribrest, I cut as much as I could with the stewmac base: ![]() and made a custom base to cut the convex portion: ![]() After routing the channels the guitar should look like this: ![]() ![]() The purfling is glued up just like normal; there is no interruption at the start/end of the bevel: ![]() Once the bindings are glued in everything is cleaned up and it's finished: ![]() Here's the finished guitar: ![]() ![]() -Ringo |
Author: | Steve Walden [ Tue Feb 19, 2008 8:04 pm ] |
Post subject: | Re: Bevel / ribrest tutorial |
I believe Lex Luthier is a genius! Too bad Superman! Ha! ![]() Thank you for the great tutorial! ![]() ![]() ![]() |
Author: | Jim Watts [ Tue Feb 19, 2008 8:41 pm ] |
Nice job Ringo, I appreciate your sharing that and it's definitely food for thought for me. Thanks! |
Author: | Jebarri [ Tue Feb 19, 2008 9:04 pm ] |
Thanks for the tutorial, I may have to try that someday. |
Author: | WaddyThomson [ Tue Feb 19, 2008 11:05 pm ] |
Cool job. That looks really nice. Front and back. ![]() ![]() ![]() |
Author: | John Kinnaird [ Wed Feb 20, 2008 6:50 am ] |
Thanks for that great tutorial Ringo. It is going directly into the archive. John |
Author: | Arnt Rian [ Wed Feb 20, 2008 7:22 am ] |
Absolutely LOVELY! Your description of the process is clear, thanks for the effort. |
Author: | Dave Anderson [ Wed Feb 20, 2008 9:26 am ] |
Yes, Thanks much for your efforts Ringo! It's Very clear and precise! ![]() BTW- Beautiful guitar !! |
Author: | Hesh [ Wed Feb 20, 2008 11:01 am ] |
Very well done Ringo - thanks for sharing with us! ![]() ![]() ![]() ![]() |
Author: | John Kinnaird [ Wed Feb 20, 2008 12:10 pm ] |
BTW, beautiful linings inside the guitar. JOhn |
Author: | DGr33n [ Mon Apr 13, 2009 3:27 am ] |
Thank you very much for sharing, I look forward to learning here at OLF |
