Routing Jig for 2-Way Martin Truss Rod Ends http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10117&t=42537 |
Author: | theguitarwhisperer [ Fri Jan 24, 2014 11:50 pm ] |
Post subject: | Re: Routing Jig for 2-Way Martin Truss Rod Ends |
But the bottom is flat. I use a 1/4 inch round bit and an edge guide for the main route, then switch to a 3/8th's round bit for the last part. If I keep the edge guide the same, the larger bit is exactly centered to the first route already and I can route the last part the correct depth by setting the depth stop. Fits perfectly and there's no square edge slot stress riser. Edge guide, router, and 2 bits. Just measure a little more carefully than I did, this one was a little sloppy I admit... ![]() |
Author: | theguitarwhisperer [ Fri Jan 24, 2014 11:56 pm ] |
double |
Author: | dzsmith [ Sun Feb 02, 2014 10:24 am ] |
Great idea Todd! I've been using Martin style rods on electrics and never thought of using a template. Dan |
