It is currently Sun Sep 14, 2025 6:42 am
PostPosted: Mon Sep 29, 2014 2:28 pm
Thought this may be of some use or interest to someone.
Fitted the router by drilling 12 mm and 8 mm holes using the router base as a template, secured the pillars with the 6 mm bolts fitting into the groves in the bottom of the pillars.
Basically I was not happy with visibility, or limited plunge depth, using the router's own base fitted to the jig.
Also note the bevel added to the cut-out round the router bit - I cut this with a guided cove bit, again to increase visibility around the bit area.
cron
