Fretboard radius sanding jig http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10117&t=45915 |
Author: | RogerC108 [ Sat Jun 20, 2015 9:43 pm ] |
Post subject: | Fretboard radius sanding jig |
Well, today I decided I needed to go ahead and rig up my swing-arm fretboard radius sanding jig for the Shop Fox sander that was given to me. It started with a 2 hr trip to Lowe's to get: -- 1/2" black pipe (which they cut into two 24" sections and two 6" sections) -- 2 floor flanges -- 1.5" square tubing -- 1/2"-13 x 36" all-thread -- two 1/4" x 2.5" eye bolts -- six 1/2" nuts -- two 1/2" PVC compression T fittings ![]() First I screwed the 24" pipe into the floor flanges. ![]() And screwed the 6" pipe into the T section of the compression fittings. ![]() In order for the compression fittings to slide onto the 24" section of pipe, I needed to thin the rubber bushings. ![]() ![]() And then I put the compression fittings back together and slid them onto the pipe. ![]() ![]() Then I drilled 1/4" holes in the 6" sections of pipe. ![]() And inserted the eye bolts. ![]() ![]() Then I cut my square tubing to proper length - 24" ![]() And inserted the all-thread with a bolt in either side. ![]() ![]() Then I attached everything to a base. I inserted the top of the all-thread into the eye bolts and secured with 1/2" nuts. I still need 2 more, though, so I can have 1 nut on both sides of the eye bolts to lock everything together. ![]() Now I loosen the compression fittings and slide each side to the appropriate radius, then attach the fretboard to the bottom side of the tubing and swing to sand. This should take me about 30 seconds as opposed to 4 hrs. I'm pretty pumped. |
Author: | unkabob [ Sat Aug 29, 2015 11:43 am ] |
Post subject: | Re: Fretboard radius sanding jig |
When it comes to simplicity, I use 80-grit glued to a piece of 24" dia. fiberglass pipe to give me a 12" radius on my fret boards. I clamp a board in place as a guide for square. Bob ![]() |
Author: | frwilliams [ Sun Mar 07, 2021 3:12 pm ] |
How did it work?? |
