It is currently Sun Sep 14, 2025 12:14 pm
 Post subject: Side fret markers
PostPosted: Mon Nov 16, 2015 6:15 pm
First name: Dale
Last Name: Hines
City: Carson City
State: Nevada
Zip/Postal Code: 89703
[*]Need some dots and don't want to wait for snail mail?
Grab a leather punch and your choice of colored plastic. Tried to add photo keeps telling me "file is too large" Gave up.
 Post subject: Re: Side fret markers
PostPosted: Thu Nov 19, 2015 11:11 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Not my idea, but one I have used successfully:
1) Drill the holes to the size you like in the side of the fretboard
2) Flip the bit over in the drill press so the butt end is down
3) Use the butt end as a punch and it will cleanly make dots that will fit the hole - I use various colors of plastic binding material
I find it helps to touch the butt end to a grinder so that the arisses (arisii? And does something round have more than one aris?) ) are sharp, and even better to grind it at a slight angle (5 degrees?) to make it more like a shearing action
Ed
These users thanked the author Ruby50 for the post: dzsmith (Thu Nov 19, 2015 12:16 pm)
PostPosted: Thu Nov 19, 2015 1:53 pm
Last Name: Lee
City: Albany Creek
State: QLD
Zip/Postal Code: 4035
I use a plastic knitting needle the same size as the hole. I got this tip from a guy that has made guitars since the Vietnam war.
A new way I tried is Fimo clay.. I have a 4 mm thick Aluminium plate, drilled with 10 or 12 5 mm holes and the same quantity of 2 mm dots. Squeeze the soft clay into all holes, then oven bake as suggested on the pack. Then press the clay dots out of the plate into a little container and superglue them into the holes. I did this to copy dots on a Fender. It worked so well I am going to try rout patterns on the fretboard top, fill the patterns, then heat the neck top with a side bending blanket to set the clay at 110°C for 30 minutes
