It is currently Sat Sep 13, 2025 11:37 am
PostPosted: Sun Nov 16, 2008 9:37 pm
I've fretted my board(ebony) and filed the end of the frets flush. I need to fill the open slot ends. What's the best way to go- black CA or CA and ebony dust? Also could someone give me a brief run down of the procedure for using CA and wood dust to fill the slot ends?
Also while I'm thinking of it... I have to glue a strip of wood on top of the truss rod so it will sit flush in the neck channel. Is it ok to use spruce and glue it with CA glue? I know some have used maple but I don't know if it matters.
Jeremy Douglas
PostPosted: Sun Nov 16, 2008 10:02 pm
I use acrylic paint to fill the end slots. I put the paint in a serynge and use a very fine needle. I let the paint dry overnight and sand the next day. The fun part is that I get to my colors (I usually use rosewood fretboards)...
PostPosted: Mon Nov 17, 2008 10:47 am
Jeremy, I just did this last night for a Cocobolo fretboard. I sanded the edges with fine sandpaper (I used 320) or so and thus filled the slots under the frets with fine dust. Then I drop in a tiny amount of thin CA into each slot. Wipe off excess and repeat until the slots are all filled. Might take 3 times or so. What is nice about this is the fill material typically matches the board very nicely and the slots are invisible.
PostPosted: Mon Nov 17, 2008 11:58 am
Thanks guys [:Y:] I'll probably try the dust and thin CA technique later today.
Jeremy Douglas
PostPosted: Mon Nov 17, 2008 9:46 pm
I just finished and you were right, the slots are nearly invisible. Thanks again.
Jeremy Douglas
PostPosted: Mon Nov 17, 2008 10:37 pm
Excellent!
