It is currently Thu Jun 12, 2025 2:27 am
 Post subject: Wet Sanding Shellac
PostPosted: Tue Mar 15, 2011 9:16 pm
First name: James
Last Name: Strange
City: Carson City
State: Nevada
Zip/Postal Code: 89701
What are my options for the liquid when wet sanding a shellac finish? LMI recommends mineral spirits, a guy on YouTube uses soapy water. I'd rather not use gnarly chemicals-I like the soapy water idea-but don't want make a gross error.
Thoughts, ideas?
Thanks! :)
jim
Mmmm....wood.
 Post subject: Re: Wet Sanding Shellac
PostPosted: Tue Mar 15, 2011 10:09 pm
I've had good luck with both mineral oil and Walnut oil, but needed more oil than I expected to.
Mike Lindstrom
PostPosted: Tue Mar 15, 2011 10:51 pm
I've used the same kind of oil that I used while french polishing, olive oil.
That guy on youtube certainly wasn't wet sanding shellac if he was using soap and water. That would be the sure fire way to screw up a shellac finish. He must have been wet sanding nitro.
How did you apply the shellac? If it was FP, then you probably need very little sanding, and consequently, very little oil.
PostPosted: Wed Mar 16, 2011 12:31 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I use water to wet-sand shellac. It hasn't screwed up any of my finishes so far....not sure why it would unless you let the water set for a couple hours. I do dry it often while sanding and then clean up after sanding with naphtha
