It is currently Thu Jun 19, 2025 11:59 pm
PostPosted: Wed Mar 16, 2011 10:44 am
Yeah, I just pretty much whipped this up out of 1/4" MDF that I had lying around, scribed my own ruler marks on it, and will use double sided tape to stick everything together when I want to do a build, also left a long tenon on it so I could shim it for neck angle, and you can also use this to do body angle.
While it isn't the most impressive, for 45 minutes of work, it'll do.
PostPosted: Wed Mar 16, 2011 9:36 pm
Well I thought it was pretty genius of me anyway! beehive
PostPosted: Wed Mar 16, 2011 9:41 pm
First name: Jim
Last Name: Outman
City: LaGrange
State: GA
Zip/Postal Code: 30240
As The Padma says, "If it gets the pig clean, use it."
PostPosted: Thu Mar 17, 2011 3:24 pm
I agree! I think it's a simple take on a very good idea from Mr. Myka.
PostPosted: Thu Mar 17, 2011 9:59 pm
First name: shad
Last Name: peters
so you will just double stick tape those pieces together and clamp the apparatus to the body?
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Thu Mar 17, 2011 10:16 pm
Essentially yes. Just make sure they are both equally spaced from the centerline, tape them in place, and clamp it all down and you're done.
PostPosted: Fri Mar 18, 2011 4:56 pm
You can angle the neck pocket using this too, just put your bridge underneath it, and you have your neck pocket angle, and you can do your pickup plane as well.
