It is currently Sun Sep 14, 2025 6:10 am
PostPosted: Wed Feb 04, 2009 4:36 pm
I have pulled of 1" radii at 180 degrees before with curly Walnut but went through 12 pieces doing so on a fox bender and a mold and finally ended up on a hot pipe. If you are wanting to stay at near .09" for the thickness of wood binding 1 1/4' radii I do all the time but use Supersoft II in advance with any figured wood. I seriously doubt you can pull of the one design with the half radii edges. just guessing they look to be about 3/8" radii and that aint goingg to happen with .09" thick wood.
PostPosted: Wed Feb 04, 2009 5:19 pm
Last Name: Garrish
Keep the wood thin and let it soak in a big dish of SS for as long as you can. Heck, maybe even boil it. Another option is to cut the cutaway part out of a solid piece of wood if you can blend it in with the rest (no bending!)
Bob Garrish
PostPosted: Wed Feb 04, 2009 10:29 pm
First name: Douglas
Last Name: Ingram
City: Lorette
State: Manitoba
You can also slice it very thin, dampen it, bend several layers around a temporary form, then they are ready to go on the final guitar. Well done, it's an invisible laminate.
Had to do my Selmer cutaway this way.
http://redrivercanoe.ca/
PostPosted: Wed Feb 04, 2009 11:29 pm
I have had no trouble bending rosewoods around a 1/2" pipe for my headstock binding. They are somewhat thin, at .06 but they bend fine. There are some woods I would be hesitant to try that tight bend with though.
Burton
Brookline, MA.
PostPosted: Thu Feb 05, 2009 12:01 am
LP horn... curly maple.
PostPosted: Thu Feb 05, 2009 1:21 am
JJ wins. [clap]
I haven't attempted anything as tight as the design on the left, but I'm sure it can be done. I would NOT want to try it with bloodwood though.
JJ, what did you use to bend the binding for the LP horn? I've heated up a screwdriver shaft with a heat gun in the past, with decent results, but I always feel like there's a better way.
PostPosted: Thu Feb 05, 2009 2:56 pm
Wasn't for a cutaway, but I bent ebony 360° for a 1" dia soundport on a small pipe with Supersoft. Next time I'll take Doug's suggestion and laminate.
