trussrod question
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10123&t=22991
Author:  therunt [ Tue Jul 07, 2009 5:40 pm ]
Post subject:  trussrod question
So I've got the scarf joint set and am ready to route the channel for the trussrod, which I have yet to order. the length of the neck from the butt of the nut to where the guitar will meet the body is 15 1/4", my question is how long of a trussrod will I need to make this work? All help is appreciated. Thank you!
Author:  Ziegenfuss [ Wed Jul 08, 2009 10:44 am ]
Post subject:  Re: trussrod question
Andrew,
generally, you just order a truss rood to the type of guitar you are building. For example, even though I use a high neck to body joint on a singlecut bass (almost at the 12th fret), I still use a full bass truss rod. Where the neck is joined to the body, it is fully constrained, but where it is free, it is free and will operate accordingly.
Stephen
Author:  therunt [ Wed Jul 08, 2009 4:06 pm ]
Ok, thank you. That makes sense, though I think I am going to set this neck aside and maybe use for a cg build later on. I decided that it was to short after comparing to the body template.
