It is currently Mon Sep 15, 2025 5:03 am
 Post subject: Bass guidance
PostPosted: Sat Sep 19, 2009 3:25 pm
First name: Jarrod
Last Name: Lovette
City: WInona Lake
Zip/Postal Code: 46590
Hello all,
I am planning on putting a jazz neck pickup on my pbass and was trying to find router depth dimensions. I can handle a router fine. Also, will a jazz bass pickguard circuit fit on a pbass? I may just try to come up with my own config. depending how much room I can figure on how to use. What configs do others like? Thanks.
 Post subject: Re: Bass guidance
PostPosted: Sun Sep 20, 2009 6:17 pm
First name: Erik
Last Name: Hauri
State: Maryland
I have a set of Bartolini J pickups and they are 0.85" tall - but the answer to your question depends on how high your strings are off the body surface. Which depends on what kind of bridge you have, and how high off the body surface your fretboard is (to the fret tops).
A good rule of thumb is that when you depress the outer strings at the highest fret (closest to the bridge), the top of the pickup should be ~1/8" from the bottom of the string. Then do the math from there.
The member formerly known as erikbojerik....
