It is currently Sun Sep 14, 2025 10:10 am
PostPosted: Sun Jul 11, 2010 9:41 am
Last Name: Neal
City: Arcadia
State: ok
Zip/Postal Code: 73007
Are hollow & semi- hollowbody ( es35 style) controls shielded? I'm thinking of building a single cutaway semi-hollowbody with the f-holes and solid centerblock and was wondering how you would shield the electronics?
PostPosted: Sun Jul 11, 2010 11:17 am
First name: Stuart
Last Name: Gort
A lot of manufacturers don't do this but I hate RF noise in the system when trying to record. There are many ways to do it but I think the easiest way for a semi-hollow body would be to paint the inside cavities with conductive paint prior to gluing up the body, and then run a ground to each cavity. Not sure how that might look when finished.....whether it would show too terribly bad through the f-hole, but if it's good paint the shield will function.
http://www.semicro.org/silverpaint-18silver15g.aspx
StuMusic
PostPosted: Tue Jul 13, 2010 9:56 am
First name: shad
Last Name: peters
if they make a conductive paint that was black i wouldnt think that would be an issue at all, your wouldnt even notice it.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Tue Jul 13, 2010 1:21 pm
I just use shielded cable. Seems to work fine.
PostPosted: Wed Jul 14, 2010 1:32 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I think you can follow Barry's advice with total confidence. I used shielded cable on my archtop, and it's a very quiet, hum-free guitar. I did ground my strings to the output jack via the tailpiece. Not sure whether that made a difference, but it sure didn't hurt.
