Neck Problems
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10123&t=29635
Author:  Hoblum [ Sun Oct 24, 2010 6:04 pm ]
Post subject:  Neck Problems
I am having problems getting a straight cut on my neck. I think I might just be impatient, if this is the case I will need to correct this, but if anyone knows any good tips or trick to use when trying to cut a solid neck blank into an angled neck please let me know.
All of the books I have read don't give me any hints. I don't have a workbench, which is probably my first problem since I don't have a table vise but I am trying to make do without.
Author:  Rusty [ Sun Oct 24, 2010 8:31 pm ]
Post subject:  Re: Neck Problems
What kind of cutting tools do you have? How did you attempt this last cut?
Author:  alan stassforth [ Sun Oct 24, 2010 9:21 pm ]
Looks like an attempt at a peghead scarf joint.
Try using a razor knife to cut your lines,
then patienly work to the lines with a rasp, then a sanding block.
Be very careful though.
Author:  Rob Warren [ Mon Oct 25, 2010 3:09 am ]
How about getting it close with a saw, and then truing it up with a plane?? Stack the short piece on top of the long piece so the angle lines up and go to town. Check frequently with a straight edge.
