Behlens Tung Oil http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10123&t=29765 |
Author: | Rusty [ Wed Nov 03, 2010 5:52 pm ] |
Post subject: | Behlens Tung Oil |
Hey guys - I have just started a couple of builds and I'm completely finishing them using Behlens Tung Oil. Do any of you have any experience with this stuff? The only concern I have is whether or not I should be adding anything to it or just continue to apply it right from the tin. It says "No dryers or thinners" on the can, but that's it. I do notice that some oil seems to pop up out of the pores here and there after I have wiped it dry. I have read that "Due to Behlen's Pure Tung Oils' concentration, a ratio of 4 parts Mineral Spirits to one part Tung Oil is suggested" ![]() |
Author: | Rusty [ Wed Nov 03, 2010 6:21 pm ] |
Post subject: | Re: Behlens Tung Oil |
Also, can I apply polymerized Tung Oil over the Behlens that I am using? |
Author: | turmite [ Wed Nov 03, 2010 7:08 pm ] |
Rusty if it is pure uncut tung oil, it will take about 4 weeks to dry, and that is for 1 coat. I bought a gallon of pure tung oil to use as a part of a finish I developed for my gunstocks and thought I would try it straight! ![]() Easy to apply, looks good, but not for a production finish. The good thing is, you can eat it if you want ![]() If you have the time to wait on the finish to fully cure, you will be amazed at the finish. Close your eyes, rub the guitar and think of a baby's rear! ![]() Mike |
Author: | Rusty [ Wed Nov 03, 2010 8:13 pm ] |
From what I have read it is not pure Tung, but very concentrated. One thing the can says is that I should wait 24 hours between coats, and that is straight out of the can and not mixed with mineral spirits. I'm assuming I can put the polymerized Tung over this. I can't think of why not. |
Author: | turmite [ Wed Nov 03, 2010 10:52 pm ] |
Rusty if the wait period is only 24 hrs it is a blend of something and tung oil. Yes you can use the poly right over the tung finish. Even better, mix 2 parts poly one part tung finish and use that. When I mixed my gunstock oil I used a mix of spar urethane, poly (exterior), pure tung oil and some mineral spirits to aid absorbtion. I bet it would make a killer guitar oil as well. I'll give it a try shortly. I am wanting to do a mesquite top/back with oil finish and this will give me the chance. Mike |
Author: | turmite [ Wed Nov 03, 2010 10:54 pm ] |
Rusty, I forgot to tell how beautiful those two bodies are. I also have a question. What is the hole in the top just above the jack? Mike |
Author: | Mike Baker [ Thu Nov 04, 2010 1:17 pm ] |
+1 on the beautiful bodies! |
Author: | Rusty [ Thu Nov 04, 2010 8:58 pm ] |
turmite wrote: Rusty if the wait period is only 24 hrs it is a blend of something and tung oil. Yes you can use the poly right over the tung finish. Even better, mix 2 parts poly one part tung finish and use that. When I mixed my gunstock oil I used a mix of spar urethane, poly (exterior), pure tung oil and some mineral spirits to aid absorbtion. I bet it would make a killer guitar oil as well. I'll give it a try shortly. I am wanting to do a mesquite top/back with oil finish and this will give me the chance. Mike I was asking about polymerized Tung oil, as in Tung Oil that has been pre-heated to start the cross link who da wadda process. But I don't think I am going to try the polymerized stuff anymore. Let me know how your mixture experiment goes. As far as the hole above the jack, I think you are referring to the 3 holes on top for the controls.. Is this correct? |
