It is currently Fri Jun 20, 2025 5:49 pm
 Post subject: Inlay has come out
PostPosted: Fri Jan 28, 2011 7:55 am
First name: Nathan
Last Name: Merry
City: Sydney
I just took off the strings on my SG and I noticed the inlay on the 12th fret was starting to come off. Its actually completely off now and I have no idea why (its an old guitar from the 80's so could be an age thing). I want to put it back in. I have a wood glue that I could use. Would there be any problems in just gluing it back in?
 Post subject: Re: Inlay has come out
PostPosted: Fri Jan 28, 2011 10:47 am
First name: Gabby
Last Name: Losch
City: Brookline
State: MA
I'd use epoxy, and maybe mix the epoxy with some ebony dust (assuming your fretboard is ebony).
PostPosted: Fri Jan 28, 2011 10:55 am
First name: shad
Last Name: peters
if you're house is pretty exceptionally dry, then the wood might have shrunk enough to pop out the inlay. some older houses can get down into the 20% humidity range in the winter. at least where i am at. epoxy ought to fixe it up right just make sure that it will fit back flush first.
~shad peters
http://www.flickr.com/photos/petersinstruments/
http://petersinstruments.blogspot.com/
http://petersinstruments.com/
PostPosted: Fri Jan 28, 2011 8:19 pm
First name: Nathan
Last Name: Merry
City: Sydney
Okay sounds like epoxy is the way to go. Anything I should know about using it? Its a rosewood fretboard. And it does fit back in perfectly flush. Any type of epoxy I should use? I am completely new to this.
PostPosted: Fri Jan 28, 2011 10:49 pm
First name: alan
Last Name: stassforth
City: Santa Rosa
State: ca
Zip/Postal Code: 95404
Epoxy might be too thick and leave the inlay proud a bit,
and you don't want to sand the inlay,
because this would be a pain, imo.
Also, it might be a sticky mess, if it comes up at da seams.
I would use some medium ca in the cavity,
and not so much that any would squeeze out.
Just enough to hold it in.
Then again,
repair work ain't my strong point!
PostPosted: Fri Jan 28, 2011 11:07 pm
Any of those would work. I use good ole' original titebond to glue inlays in, and have never had the slightest problem. If I had to choose something else, I'd use CA.
PostPosted: Fri Jan 28, 2011 11:09 pm
First name: Nathan
Last Name: Merry
City: Sydney
Okay, ill get the ca glue then. Easier for me to get today anyway.
PostPosted: Sat Jan 29, 2011 7:24 pm
First name: Nathan
Last Name: Merry
City: Sydney
Okay it's stuck back in. Thanks for all the help. I screwed it up a bit, wasnt quiet flush so theres a bit sticking up. Dried so quick though. Ah well, still looks okay.
