Level sanding lacquer between coats with cabinet scraper? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10123&t=37210 |
Author: | Irving [ Wed Jul 25, 2012 10:43 am ] |
Post subject: | Level sanding lacquer between coats with cabinet scraper? |
I've used stearated sandpaper over the years, which still gums up pretty badly after a few moments of use. Has anyone ever tried using a cabinet scraper to level the finish? I was using a razor blade to level and blend a few spots that I had drop filled and out of curiosity I started to do it to the entire backside of the guitar with the tiny razorblade. It worked surprisingly well and got me thinking that perhaps I could use my scraper to do the whole thing. It would never gum up, and does not consume time replacing sandpaper. Anyone ever tried it? |
Author: | B. Howard [ Wed Jul 25, 2012 3:28 pm ] |
Post subject: | Re: Level sanding lacquer between coats with cabinet scraper? |
I use a scraper on my epoxy pore fill to level it. It does gum up as the edge heats up. I would be more worried about cutting through the nitro in spots with a scraper than sandpaper. Try using less pressure and a lighter touch when level sanding, again it's the heat that causes the gumming and seeding on the paper. You could wet sand to level as well. |
Author: | Irving [ Wed Jul 25, 2012 6:33 pm ] |
Good point about the heat gumming the lacquer up. Hadn't thought about that. |
