It is currently Wed Jun 18, 2025 4:42 am
PostPosted: Fri Dec 14, 2012 4:29 pm
First name: James
State: Maine
In order to get proper string height to be compatible with a standard 4 string bridge, how high do you leave the crown of the fretboard off of the bass body surface when routing your neck pocket? I was thinking around 12/32".
In other words, if I did this and ran a straightedge down the fretless fretboard and over the bridge area there would be 12/32" of clearance over the body surface.
What measurement do you go for that works well?
PostPosted: Sat Dec 15, 2012 12:26 pm
First name: David
Last Name: Morris
City: McKinney
If you have adjustable saddles, there's room for error. I generally put the bridge on the body, measure the height, and use that as the determining factor. The specific depth of your neck pocket will depend on a number of factors, including the thickness of your neck heel, bridge height, and the method you use to mount your bridge. It's best to just lay it out and think through it, in my opinion.
David Morris
PostPosted: Sat Dec 15, 2012 11:41 pm
First name: Mark
Last Name: Sorrentino
Yep. Measure the total thickness of your neck at the heel, including the top of your fret (Measurement A). Measure your bridge saddle height at its lowest position, or close to it (Measurement B). Measurement A minus Measurement B = your neck pocket depth.
PostPosted: Sun Dec 16, 2012 1:53 am
City: chicagoland
State: illinois
i think this is one of those rare cases in woodworking where too much of a cut is acceptable....you can always shim the neck if your pocket is too deep... also, make sure to set the adjustable saddles about halfway in their vertical range before guestimating, and try to compensate for neck curvature/nut rise under string tension
PostPosted: Sun Dec 16, 2012 6:21 pm
First name: James
State: Maine
I went for 16/32". A bit on the high side but I think it'll work out.
