Nut slots...How do you do it?
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10123&t=38429
Author:  WindyCityBluesBox [ Tue Dec 04, 2012 2:20 am ]
Post subject:  Nut slots...How do you do it?
Im curious as to what some other people's techniques for this are. I set my table saw at a low depth and use a crosscut fence to carry the fretboard across the saw blade and a 90 degree angle (after running a few test cuts of course). Im curious in particular about how some oh you do the non fender-style nut slot (like gibsons, acoustics, ect.) I cant think of a good way to do this other than a dremel with an end-milling bit and a dremel stand.
Author:  nyazzip [ Tue Dec 04, 2012 4:02 am ]
Post subject:  Re: Nut slots...How do you do it?
"gibsons, acoustics, etc" don't use a nut slot- they chop the fretboard off and the nut butts up against that terminus. most stringed instruments throughout the ages are that way
Author:  klooker [ Tue Dec 04, 2012 10:53 am ]
The peghead veneer will act as the other end of the slot.
I use a Japanese style saw to square up the peghead veneer then fine tune it with a chisel.
Kevin Looker
Author:  John Coloccia [ Wed Dec 05, 2012 7:36 am ]
I have a dummy nut that I was very careful to size to exactly .180", dead flat and square. When I glue on the fingerboard, I sandwich the nut between the fingerboard and the head plate. Instant nut slot.
Author:  theguitarwhisperer [ Thu Dec 06, 2012 12:28 pm ]
Sometimes I cut the fretboard off at the nut ans use that as the nut slot in conjunction with the head plate. I use a fret slotting handsaw for this. For a fender style nut, after slotting the fretboard on my table saw, I make another kerf 1/8th past the zero fret kerf in the direction of the tuning keys and chisel the wood in between out with a sharp micro chisel.
Author:  Chris Pile [ Thu Dec 06, 2012 3:32 pm ]
Clever fellow.
I wonder if that's how Gibson does it on some of their stuff?
Author:  John Coloccia [ Thu Dec 06, 2012 7:26 pm ]
Chris Pile wrote:
Clever fellow.
Don't know. I know that other builders do it like that, though no one ever seems to talk about it because I don't know anyone who "got" that from someone else. It always seems like it's something we just started doing one day out of laziness. When this batch of 2 guitars is done, I'm going to try dumping the nut slot entirely and just sticking the nut back there flat. The whole nut slot thing just kind of seems like a complete waste of time and energy, both for me and for whoever needs to replace the nut later.
Author:  Chris Pile [ Thu Dec 06, 2012 7:48 pm ]
Works for me.
