It is currently Sun Sep 14, 2025 7:16 pm
 Post subject: Truss rod diy
PostPosted: Sun Nov 01, 2015 12:21 pm
First name: Alexander
Last Name: Baev
City: Zaporozhye
Zip/Postal Code: 69093
Country: Ukraine
Hello friends.
I want to make a truss rod for my two hand tapping instrument (something like Stick or Megatar). I want to install two truss rods of the same construction. http://www.stewmac.com/Materials_and_Su ... s_Rod.html
Making the brass part had no any difficulties. But making the threads on the rods became total mess. I used spring steel. After the cutting die the part of the rod with the thread deviated from strait line (I attached the picture).
Is there some trade secret?
Should I use exactly spring steel?
Thanks.
 Post subject: Re: Truss rod diy
PostPosted: Sun Nov 01, 2015 5:42 pm
Привіт від Україньця що родився в США!
Spring steel is a very hard steel and it would be very difficult to cut with a standard die. Ideally, the threads would be rolled as rolled threads are stronger but that takes very specialized and expensive equipment.
I'd recommend getting a new die (the one you used is probably ruined) and using a mild steel. If you need a little more strength, you can always use a slightly larger rod.
These users thanked the author Andy Birko for the post: baev_al (Sun Jan 31, 2016 10:59 am)
PostPosted: Sat Nov 07, 2015 1:04 am
Last Name: Baev
City: Zaporozhye
Country: Ukraine
Привіт з України!!!
Thank you for the advise.
Checked your bandura - very great job!!!
PostPosted: Fri Jan 29, 2016 3:57 pm
First name: Stuart
Last Name: Gort
1018 steel is weldable, machinable, easy to get, and cheap. It's what many truss rods are made from.
A roll formed thread is stronger but the amount of tension required to snap a two-way rod made from 1018 is also enough to destroy the wood around it before it breaks. There's a substantial torque load on a truss rod before is snaps so it's hard to figure exactly....but with no torque present...950-1000 lbs. of tension is about where 1018 will snap on a 3/16-24 or 32 cut thread. Give or take...the fine thread will hold a little more before it snaps.
A cut thread is weaker but it's a LOT easier for you make. It will come nowhere near breaking under the minor loads necessary to offset string tension loads....or the minor bends that may be required to offset other building issues.
Obviously...we shouldn't be using truss rod to correct serious building issues...so go ahead and cut the threads in a 1018 steel rod. I promise it'll go easier for you in every respect fabricating it...and it won't break unless you make banana necks. :)
For what it's worth...I'm in the process and breaking and quantifying loads several steel truss rods for the purposes of making a direct comparison to a composite truss rod I'm developing. I've broken lots of steel rods so far in a specialized jig meant to present a very practical and demonstrable comparison between steel and composite.
If the welds do not break (which happens fairly frequently in these tests) then the next break will occur in the minor thread diameter when the threaded bar is in tension. Believe me when I say that just prior snapping...there is a LOT more stress there than any decent luthier should be having to apply. Many times more....in fact.
When I can fix this issue....I'll REALLY have something.
StuMusic
These users thanked the author Stuart Gort for the post (total 2): baev_al (Sun Jan 31, 2016 10:59 am) • Jason Rodgers (Sat Jan 30, 2016 10:55 am)
PostPosted: Fri Jan 29, 2016 5:00 pm
Is that one of those new fangled scalloped fretboards?
PostPosted: Sun Jan 31, 2016 12:03 pm
Last Name: Baev
City: Zaporozhye
Country: Ukraine
It seems that stick truss rod construction is really good for this. I didn't want to use this idea because I don't like that the rod is open, but it seems as the easiest way...
Any comments are highly appreciated.
PostPosted: Sun Jan 31, 2016 2:39 pm
First name: Rusty
[WHITE HEAVY CHECK MARK]
