It is currently Sat Sep 13, 2025 6:54 am
PostPosted: Sat Aug 24, 2019 10:05 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
A Cuban “tres” guitar is often based on a regular 6-string body-neck style, modified as necessary to install 3 double-string courses. One of my semi-pro clients wants to add one to his stable. We are starting with an archtop with trapeze tailpiece, making the arrangement of strings straightforward.
My question concerns pickups that would be appropriate for the 3 courses of double strings. I presume this would exclude all PUPs designed around 6 pole pieces. So what then? Rails? A piezo-style is a possibility, but then the acoustics of the body become a much bigger (and limiting) factor.
A noiseless pup would obviously be preferred, but at this stage, the size and format is not a concern (we can do the required woodwork for up to 3 pickups). It mostly needs to work with three string courses!
PostPosted: Sat Aug 24, 2019 12:00 pm
First name: Freeman
Last Name: Keller
Tim, are you expecting the soundboard to be active or will you be bracing it to be structural supporting the pup(s) (in other words, a true acoustic archtop that needs to be amplified or something more like an ES-175 or L5)? I guess the other way to ask that is do you want a magnetic p/u or some sort of acoustic/piezo one?
I built an archtop looking acoustic guitar for a friend but he wanted the option of plugging it in, we settled on building K&K transducers into the guitar - they were installed before the box was closed since there is no access).
PostPosted: Sat Aug 24, 2019 4:38 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
I should clarify that the plan is to modify an existing, not-too-expensive archtop. Most such used guitars seem to have at least one P90 or humbucker already installed, but these would be useless on a 3 course string arrangement. So, I was thinking of replacing with a magnetic pickup that is less sensitive to string arrangement.
The attraction of a magnetic PUP was it’s feedback control on stage and being less sensitive to the acoustic quality of the instrument. However, I did today find a used Godin archtop without any electrics and wonder if a piezo PUP designed for a Bouzouki might work well (for example, the Schatten Design BM-1).
PostPosted: Sat Aug 24, 2019 6:35 pm
First name: Freeman
Last Name: Keller
I understand Tim. Would one of the blade or rail style pickups work? SD makes them in various configurations. Also I recently worked on a bajo quinto and it had a soundhole magnetic pickup that was basically a cylinder with some spring loaded tabs on the ends. A bajo quinto is a five double course instrument and apparently this pup worked fine. Last though, if you are going to use an archtop style bridge there are some with built in piezos
These users thanked the author Freeman for the post: Tim Mullin (Sun Aug 25, 2019 2:20 pm)
PostPosted: Sun Aug 25, 2019 8:15 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
What type of music is played? That is a very important part of the equation. Most rail Pups are really hot!
I would think maybe a cheap 60's foil type Pup.
Brian
These users thanked the author B. Howard for the post: Tim Mullin (Sun Aug 25, 2019 2:23 pm)
PostPosted: Sun Aug 25, 2019 2:29 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Have no idea what that PUP might be, but sounds interesting.
Certainly that's a fallback, although I was hoping to avoid stage feedback so hoping to go magnetic.
That was exactly my concern when I looked at offerings from DiMarzio and SD. The attraction was that odd string spacings might not be problem.
Now THERE's an idea!! Gosh, I had one on an old Regal through the shop a couple of weeks ago and never thought about it for this project. I see some have 6 faux pole positions indicated on the outside, some just a blank foil -- are they usable for ANY string arrangement?
PostPosted: Tue Aug 27, 2019 6:12 pm
First name: Leo
Last Name: Pedersen
City: Bowen Island
State: British Columbia
Zip/Postal Code: V0N 1G2
There are quite a few non-polepiece pickup designs available.
I've had good experiences ordering from a Canadian eBay store called Bezdez.
Here's an inexpensive example which I've tried and liked: https://www.ebay.ca/itm/HIGH-OUTPUT-BLADE-HUMBUCKER-GUITAR-PICKUP/202573452661?hash=item2f2a519575:g:8sEAAOSwyDxXhvNA
I also really like Lace Alumitones: https://lacemusic.com/collections/7/products/alumitone-humbucker
These users thanked the author Durero for the post: Tim Mullin (Wed Aug 28, 2019 12:51 pm)
