Control Cover
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10123&t=52691
Author:  Chris Ensor [ Sat Nov 30, 2019 4:14 pm ]
Post subject:  Control Cover
Any reason I shouldn't use steel for the control cover? And magnets to hold it down? The magnets would be imbedded in the body.
Thanks.
Author:  Chris Pile [ Sat Nov 30, 2019 6:17 pm ]
Post subject:  Re: Control Cover
It rusts? Conductive?
Author:  SteveSmith [ Sat Nov 30, 2019 9:22 pm ]
Chrome it or get it powder coated.
Author:  Chris Ensor [ Mon Dec 02, 2019 7:01 pm ]
Plan would be to blue it (or something similar) to avoid rusting. As long as nothing is touching it, is its conductivity a problem?
Author:  Barry Daniels [ Mon Dec 02, 2019 8:07 pm ]
As long as it doesn't touch any lugs you will be good. Won't have to worry about shielding it either.
Author:  Mike_P [ Mon Dec 02, 2019 8:25 pm ]
don't see any issues...my Jackson Rhoads has a brass pickguard/control mounting plate, my Frankenstrat has a steel one...system is of course grounded to the plate...I assume you are referring to just a control cover on the back of a guitar as opposed to like on a strat...for some reason having the field generated by what I assume are going to be super magnets tickles a worry, but I don't know any facts in regards to that...
bluing will still rust, stainless steel still rusts...I can't tell what the coloring is made by on my 18 lb. strat monstrosity, but it doesn't look like bluing to me as it's too black and just plain doesn't look like any bluing I've ever seen on a gun
as to magnets, why? clean look I know, but just what is the plan for removal? I guess a stronger magnet can be used to get it to pull off, but then you have to get that magnet off the plate!
Author:  Chris Pile [ Mon Dec 02, 2019 9:54 pm ]
NOPE. That's why it's called stainless.
Author:  Conor_Searl [ Mon Dec 02, 2019 10:31 pm ]
I've seen guys use little "divots"(?) under the corners of a cover when you push on the cover it pops the control plate up. Pretty slick.
Author:  Mike_P [ Tue Dec 03, 2019 6:57 pm ]
try telling that to my father who used to think that before he left his stainless steel Ruger Security Six wet...
https://www.polymersolutions.com/blog/w ... teel-rust/
any more shots from the peanut gallery?
Author:  DavidSchwab [ Sun Dec 08, 2019 2:40 pm ]
G&L use powder coated steel for control and neck plates. Not stainless either since they are magnetic. (Yes, some stainless is magnetic. I use it in pickups)
Author:  alan stassforth [ Fri Dec 20, 2019 10:48 am ]
Hey Chris, what did you end up doing?
Mike P, nice info on the stainless.
Alan
Author:  Chris Ensor [ Fri Jan 03, 2020 2:46 pm ]
Alan
Alan,
I made a steel cover. The inside and edge is painted black for rust prevention. The outside has been flame treated for visual effect and I'm thinking about clear coating it as well- again for rust prevention. It's held in place by rare earth magnets. I made a handle with a large rare earth magnet for removal. Works well.
Author:  kfish [ Sat Feb 08, 2020 12:36 pm ]
I saw one builder use a 4 point cover with magnets under 3 of them. So you can push down on the 4th point/corner and the opposite corner would pop up.
