More Paduck Pics " Updated " http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10128&t=30292 |
Page 1 of 2 |
Author: | WudWerkr [ Sat Dec 11, 2010 11:58 am ] |
Post subject: | More Paduck Pics " Updated " |
I am currently waiting on some Super Soft II I have ordered . After breaking the second side it became clear that a new route was needed . In the meantime I have done rough work on the top and back. There is still cleanup work to be done , however the basics are there. Attachment: 100_0880.jpg Attachment: 100_0881.jpg Attachment: 100_0882.jpg Attachment: 100_0883.jpg Attachment: 100_0885.jpg Attachment: 100_0886.jpg
Author: | Chris Oliver [ Sat Dec 11, 2010 12:03 pm ] |
Post subject: | Re: More Paduck Pics |
Author: | WudWerkr [ Sat Dec 25, 2010 3:38 pm ] |
I have been working on the fretboard and getting it ready to fret . I have encased the fretboard in Cocobolo, the 1/4" Strip running down the neck is a vertical piece . The 1/8" thick piece under the fretboard as well as the binding all glued in place will/ should make for a fairly stable neck. I HOPE The Cocobolo had more sapwood in it than I would have liked , However I dont believe that it will be to much of a factor. I am waiting to try and get some Padauk Dots for the fret board inlays . I may have to make them , but am looking around first. Attachment: 100_0888.jpg Attachment: 100_0889.jpg Attachment: 100_0890.jpg Attachment: 100_0891.jpg Attachment: 100_0892.jpg Attachment: 100_0893.jpg
Author: | Ti-Roux [ Sat Dec 25, 2010 4:25 pm ] |
You should give a try to white glue, that dries clear... or even hide glue. Or maybe clean this glue before it get dry. |
Author: | WudWerkr [ Sat Dec 25, 2010 5:02 pm ] |
I am using titebond orig. I appreciate the suggestion , i guess im not sure where u are refering to in the post . the top and back inside ? |
Author: | Ti-Roux [ Sat Dec 25, 2010 5:20 pm ] |
I'm refering to the top. We see the yellow dried glue all along the braces. Once dried, Titebond is really a mess to clean up nicely. Clean it with hot wet rag when it's still fresh, it will save you a lot of trouble. |
Author: | WudWerkr [ Sat Dec 25, 2010 9:01 pm ] |
Ti-Roux wrote: I'm refering to the top. We see the yellow dried glue all along the braces. Once dried, Titebond is really a mess to clean up nicely. Clean it with hot wet rag when it's still fresh, it will save you a lot of trouble. Thanks for the suggestion ! ![]() |
Author: | WudWerkr [ Mon Jan 03, 2011 1:39 pm ] |
Modified the fretboard a little , just to be different. And b4 anyone goes and starts accusing me of herasy , ![]() ![]() ![]() Attachment: 100_0904.jpg WHY IS IT That the very LAST fret wire installed is ALWAYS the one that tries and tears out ?? ![]() |
Author: | Chris Oliver [ Fri Jan 07, 2011 8:27 am ] |
Nice fret markers.. I didn't know if you would be able to see them. ![]() Don't you dare glue that fretboard on there until you fix the fretboard... remove fret, dam groove, ac glue fill with dust, sand level, clear slot, new fret, no problem! |
Author: | WudWerkr [ Fri Jan 07, 2011 9:26 am ] |
To be honest Chris , I thought about taking it out and filling with glur and ebony dust , sanding flat and leaving it out . It isnt a playable fret anyway . I havent decided , It is glued in , and needs a lil more touch up . |
Author: | Chris Oliver [ Sat Jan 15, 2011 6:55 pm ] |
WudWerkr wrote: To be honest Chris , I thought about taking it out and filling with glur and ebony dust , sanding flat and leaving it out . It isnt a playable fret anyway . I havent decided , It is glued in , and needs a lil more touch up . Did you get it out of there yet? |
Author: | WudWerkr [ Sun Jan 16, 2011 6:26 pm ] |
No chris I havent done anymore with it in tha last week or so , I have been buffing the pearblossom and I made the pickguard . I am going to finish it out I think B4 I go any further on this one . I need Quartersawn Padauk for sides . All I have is flawsawn and I have had no sucess in bending without breaking them . I will get back on it soon though. Stop by the pearblossom thread and tell me what you think of my pick guard . |
Author: | StevenWheeler [ Mon Jan 17, 2011 6:40 pm ] |
WudWerkr wrote: I need Quartersawn Padauk for sides . All I have is flawsawn and I have had no sucess in bending without breaking them. Hey Jim, Guess what i found yesterday. PM your address to me and I'll get this board in the mail to you. Steve |
Author: | Chris Oliver [ Wed Mar 02, 2011 10:59 pm ] |
James.... what's going on here? The weather has stunk too much to be outside over the last month... No pressure. ![]() |
Author: | WudWerkr [ Fri Mar 04, 2011 8:40 am ] |
Thanks for the interest chris , ![]() ![]() I have been building a second bathroom im my basement , "just for dad" ![]() ![]() I will be back in shop sooon and look forward to posting more on it soon ! |
Author: | WudWerkr [ Thu Mar 31, 2011 10:42 am ] |
I have successfully bent the Padauk sides . ![]() ![]() Attachment: 100_1032.jpg Attachment: 100_1034.jpg Attachment: 100_1035.jpg Attachment: 100_1036.jpg Attachment: 100_1037.jpg
Author: | WudWerkr [ Mon Apr 04, 2011 11:58 am ] |
Tried my hand at my first binding this weekend . I am sure I made several mistakes , but we shall see when its sanded . I used TiteBond Orig. to glue the binding . Is there a better choice? After the binding was set I set the neck and angle . Its held in right now by a drywall screw . I have found they work very well for the smaller Mando's . Attachment: 100_1038.jpg Attachment: 100_1044.jpg Attachment: 100_1045.jpg Attachment: 100_1046.jpg Attachment: 100_1048.jpg Attachment: 100_1049.jpg Attachment: 100_1050.jpg
Author: | Chris Oliver [ Mon Apr 04, 2011 11:04 pm ] |
Lookin' good James. I use the same glue although... .I use a lot of tape to hold the binding on as I go... and use the large rubber bands after complete. Attachment: Binding-install.jpg Keep up the good work.... |
Author: | WudWerkr [ Tue Apr 05, 2011 7:45 am ] |
Post subject: | Re: More Paduck Pics Update |
I started sanding the binding and some of it came loose ![]() ![]() We shall see if it sticks this time |
Author: | Ian Cunningham [ Wed Apr 06, 2011 7:24 am ] |
Love that headstock. Can't wait to see it finished. |
Author: | WudWerkr [ Thu Apr 21, 2011 2:48 pm ] |
Post subject: | Re: More Paduck Pics " Updated " |
A few more pics of the Padauk Build Top is on , Back is on , Neck is set and the binding has been routed . Attachment: 100_1067.jpg Attachment: 100_1066.jpg Attachment: 100_1068.jpg Attachment: 100_1070.jpg The Binding will be cocobolo to match the neck and headstock |
Author: | fric [ Sat Apr 23, 2011 4:08 pm ] |
WudWerkr wrote: IF I EVER talk about building with this again someone shoot me !! ![]() ![]() ![]() ![]() I know how are you feeling |
Author: | Alexandru Marian [ Sat Apr 23, 2011 4:46 pm ] |
At what thickness did you bend? |
Author: | WudWerkr [ Sat Apr 23, 2011 6:38 pm ] |
the sides are .075 thick and I bent with a bending iron ![]() |
Author: | Alexandru Marian [ Sat Apr 23, 2011 6:55 pm ] |
Thanks. Good to know as I have a set I might use in the near future. Very nice taptone - this wood seems to have a huge bang for the buck factor, although the color is kind of crazy. Mine doesn't feel particularly dense and I was planing 0.08 but I might go thinner now. |
