It is currently Sat Sep 13, 2025 1:32 pm
PostPosted: Tue Dec 31, 2013 5:56 am
First name: Gary
Last Name: Gill
City: Greenwood
State: Indiana
I have created a problem here. The body is quarter sawn cherry and the binding is quarter sawn maple. From the photos you can see the maple binding not completely seated about an inch & a half shy of the butt joint. I used Locite brand super glue as the adhesive. I applied the glue from the top side only in this area. Would you suggest?
1) Use a heat gun on the binding and expect the glue to loosen? Then re-position and glue in proper position.
2) Should I make a tapered strip of maple and fill the gap?
3) Rout the binding off and start again?
I appreciate the advice. This is my twelfth ukulele but only second attempt at binding.
[img][IMG]http://i9.photobucket.com/albums/a81/N9ZYE/PT-731dec13Top.jpg[/img][/img]
[img][IMG]http://i9.photobucket.com/albums/a81/N9ZYE/PT-731dec13Bindnggap-1.jpg[/img][/img]
[img][IMG]http://i9.photobucket.com/albums/a81/N9ZYE/PT-7bindinggap2.jpg[/img][/img]
PostPosted: Tue Dec 31, 2013 8:54 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Try the heat, but I would probably rout it off and redo the binding. I am wondering how you plan to cut out and inlay the butt splice you have marked with the binding on.
Fred
Fred Tellier
PostPosted: Tue Dec 31, 2013 8:57 am
First name: Gary
Last Name: Gill
City: Greenwood
State: Indiana
The splice is over the dovetail neck joint. Will acetone loosen the super glue?
PostPosted: Tue Dec 31, 2013 9:31 am
First name: Alain
Last Name: Lambert
City: Trois-Rivieres
State: Quebec
Try acetone it might work.
There are also release agents like this: http://www.3mdirect.co.uk/p-2460-3m-sco ... -20ml.aspx
I never tried it.
Worst case rerout and redo.
PostPosted: Tue Dec 31, 2013 9:35 am
First name: Gary
Last Name: Gill
City: Greenwood
State: Indiana
Acetone worked. I have peeled back to where it fits rights. I plan to clean up the residue and carry on. Thanks for the help.
