Upper transverse bracing
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10128&t=47614
Author:  bcombs510 [ Mon Apr 11, 2016 11:17 am ]
Post subject:  Upper transverse bracing
Hello,
I'm building a tenor uke, the first one from scratch for me. I've built a couple of the SM uke kits.
I searched here and it seems about 50 / 50 in favor or radius the top or flat. I put a 30' radius on the rims and glued the waist and fan braces on after radiused to 30'. I glued them up in a radius dish / go bar just like I use on guitar.
Question: When building a guitar I've put the upper transverse brace on flat to try to avoid a gap at the fretboard extension. Do the same for the Uke? It seems like it would be the same, but I'm curious if others do the same?
Thanks!
Brad
Author:  Quine [ Mon Apr 11, 2016 12:08 pm ]
Post subject:  Re: Upper transverse bracing
I use an upper transverse brace on my ukes. I make it the same size as the lower transverse
Author:  bcombs510 [ Mon Apr 11, 2016 12:30 pm ]
Does that mean radiused the same as well? :)
Author:  Alain Lambert [ Mon Apr 11, 2016 5:10 pm ]
I radius mine to 30 ft also. The Uke is so small you can barely see the radius, I do not remember any problem fitting the neck/FB. May be a little sanding to get the area under the FB flat. Assuming you extend the FB to the sound hole.
Author:  bcombs510 [ Tue Apr 12, 2016 1:07 pm ]
Thanks. I went ahead and glued it on flat for this one, let's see how it goes. :)
Thanks!
Brad
