Master Grade Australian Blackwood Tenor Uke http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10128&t=50651 |
Author: | Allen McFarlen [ Sat May 19, 2018 6:05 pm ] |
Post subject: | Master Grade Australian Blackwood Tenor Uke |
I rarely post my work here but thought some might like to see what I keep busy with. This is just one out of a set of 5 instruments I'm sending to a client in Hong Kong. Australian Blackwood body and bindings with Ebony head plates and fret board with compound radius. Waverly machine heads, K&K Aloha Twin pickup. Amber bone nut and saddle. Finished in high gloss polyurethane. Attachment: Australian Blackwood Tenor Ukulele1.jpg Attachment: Australian Blackwood Tenor Ukulele3.jpg Attachment: Australian Blackwood Tenor Ukulele4.jpg Attachment: Australian Blackwood Tenor Ukulele8.jpg Attachment: Australian Blackwood Tenor Ukulele9.jpg Attachment: Australian Blackwood Tenor Ukulele10.jpg Attachment: Australian Blackwood Tenor Ukulele12.jpg
Author: | Jim Watts [ Sat May 19, 2018 6:13 pm ] |
Post subject: | Re: Master Grade Australian Blackwood Tenor Uke |
Wowzer, that's a real beauty Allen! Thanks for posting. |
Author: | mflazar [ Sat May 19, 2018 8:01 pm ] |
Exquisite !!!! |
Author: | Glen H [ Sat May 19, 2018 8:04 pm ] |
Makes me want to take up ukes! |
Author: | Pmaj7 [ Sat May 19, 2018 10:56 pm ] |
I can describe that uke in three words: Dy no mite Sent from my SM-N910T using Tapatalk |
Author: | johnparchem [ Sat May 19, 2018 11:58 pm ] |
Oh my. The ukulele is absolutely gorgeous. |
Author: | Allen McFarlen [ Sun May 20, 2018 1:17 am ] |
Thanks everyone. I might have to post a bit more often here. |
Author: | Aaron O [ Sun May 20, 2018 2:48 pm ] |
I always appreciate seeing your craftsmanship. I may not always comment, but I always look. . . Keep posting please. |
Author: | Bryan Bear [ Sun May 20, 2018 2:50 pm ] |
Lovely. I like how all the elements came together. |
Author: | sdsollod [ Sun May 20, 2018 4:17 pm ] |
Absolutely amazing work! How do you do that purfling on the soundport? |
Author: | J De Rocher [ Sun May 20, 2018 4:28 pm ] |
That's a gorgeous instrument! I'm a big fan of your work and aesthetics so it's great to see another one. The oval sound hole fits the body shape beautifully. This one is strong competition for my favorite which was the ancient spruce/ambrosia maple one from a couple years ago. Is this new one the same body shape/size as the ambrosia maple uke? |
Author: | Allen McFarlen [ Sun May 20, 2018 8:46 pm ] |
I've done several Ambrosia Maple and Ancient Spruce ukes. Tenors mostly, so this would be the same body size. Gotta 6 string tenor on the go right now. For the sound port I cut the binding material out of the same material I'm binding the rest of the instrument with. I use my laser, but you could do it by hand. Then I glue the purfling around that piece. After thats dry I bend that piece to suite the contour of the sides. Then scribe the outside and cut that area out to fit. Dremel work with a small sanding drum to sneak up on the fit. Once it fits I glue in place with CA. And finally I have another veneer that I cut on the laser with the same inside hole size, and larger outside to act as a backer. Bend to fit and glue in place. After doing quite a few it gets easy with total job taking about an hour. |
Author: | Bob Orr [ Mon May 21, 2018 8:50 am ] |
Wonderful. Never thought about making up a sound port ring then bending it to suit the contour. If you don't mind me thieving your method I may try that on my next guitar. Bob |
Author: | Allen McFarlen [ Mon May 21, 2018 4:26 pm ] |
Bob Orr wrote: Wonderful. Never thought about making up a sound port ring then bending it to suit the contour. If you don't mind me thieving your method I may try that on my next guitar. Bob No worries Bob. I'd tried a few different ways, but this seems to make the most sense to me with the tooling I have, and wasy way easier to get the look I'm after. |
