Ukulele binding jig? http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10128&t=51332 |
Author: | Steve-atl [ Thu Dec 13, 2018 1:45 pm ] |
Post subject: | Ukulele binding jig? |
I was thinking of picking up one of LMIs Binding Machines and the binding machine carrier. I called and they said the binding machine carrier will not scale down to fit a Ukulele. Does anyone of a binding jig made for a Ukulele? Thanks |
Author: | Allen McFarlen [ Thu Dec 13, 2018 3:19 pm ] |
Post subject: | Re: Ukulele binding jig? |
I only use the StewMac binding router bits with bearings in my Makita laminate trimmer. No jigs, holders etc. Over 300 ukes now and can't imagine needing anything more complicated. |
Author: | Pmaj7 [ Thu Dec 13, 2018 7:29 pm ] |
I'm not sure how the LMI works, but I have a Blues Creek jig and carriage. It allows me to flip the foam piece around and it works great for ukulele. You can't go wrong with Blues Creek! ![]() New username, same ole Pat Mac |
Author: | Ben-Had [ Thu Dec 13, 2018 7:45 pm ] |
Steve-atl wrote: I was thinking of picking up one of LMIs Binding Machines and the binding machine carrier. I called and they said the binding machine carrier will not scale down to fit a Ukulele. Does anyone of a binding jig made for a Ukulele? Thanks I use LMIs jig and made my own cradle for ukuleles and it works fine for me. |
Author: | Ruby50 [ Thu Dec 13, 2018 9:52 pm ] |
I got one of these $35 binding jigs from Ken Cierpowski (no longer in business I think). I have used it with success on 7 guitars, but on the only uke I built I was able to clamp it in the vice and pass the body over it. Very simple, quick, effective, and almost foolproof. |
Author: | johnparchem [ Fri Dec 14, 2018 10:26 am ] |
You need a closely sized cradle for any of the tower binding systems or the cradle will bump into the tower. I drilled some ukulele holes in my cradle and installed brass inserts; a very easy modification. but I use a Fleischmann binding system that reaches over the cradle. |
Author: | Pmaj7 [ Sat Dec 15, 2018 1:06 am ] |
johnparchem wrote: You need a closely sized cradle for any of the tower binding systems or the cradle will bump into the tower. I drilled some ukulele holes in my cradle and installed brass inserts; a very easy modification. but I use a Fleischmann binding system that reaches over the cradle. I hadn't thought about that, but yes I use a Fleischman style also.New username, same ole Pat Mac |
Author: | Steve-atl [ Sat Dec 15, 2018 4:26 pm ] |
I love this forum!!! I have used a router with binding router bits and bearings to cut slots on a guitar and it worked fine, but the Ukulele has a slight curve to the back. I am afraid the binding slot will not be cut straight. Am I over thinking this? |
Author: | Steve-atl [ Sat Dec 15, 2018 4:30 pm ] |
Ben-Had wrote: Steve-atl wrote: I was thinking of picking up one of LMIs Binding Machines and the binding machine carrier. I called and they said the binding machine carrier will not scale down to fit a Ukulele. Does anyone of a binding jig made for a Ukulele? Thanks I use LMIs jig and made my own cradle for ukuleles and it works fine for me. I think I posted this on the wrong response and now I can't see how to delete it That looks sweet Are those blocks of wood with rubber around them? Where did you get the rubber |
Author: | Aaron O [ Sun Dec 16, 2018 4:25 pm ] |
Made my own, too easy. Both the jig and the cradle. See post #13. It’s since been updated with a DeWalt DW611 and a Zero-bar style bearing foot (made that too). https://forum.ukuleleunderground.com/sh ... -box/page2 Note, the cradle is set for one size, but it can easily be made adjustable. Most guys I know that use a binding jig for ukulele have an LMI or SMD. Haven’t seen anyone around me with a parallelogram. |
Author: | Pmaj7 [ Sun Dec 16, 2018 8:15 pm ] |
Steve-atl wrote: Ben-Had wrote: Steve-atl wrote: I was thinking of picking up one of LMIs Binding Machines and the binding machine carrier. I called and they said the binding machine carrier will not scale down to fit a Ukulele. Does anyone of a binding jig made for a Ukulele? Thanks I use LMIs jig and made my own cradle for ukuleles and it works fine for me. I think I posted this on the wrong response and now I can't see how to delete it That looks sweet Are those blocks of wood with rubber around them? Where did you get the rubber New username, same ole Pat Mac |
Author: | Pmaj7 [ Mon Dec 17, 2018 11:03 pm ] |
Ruby50 wrote: I got one of these $35 binding jigs from Ken Cierpowski (no longer in business I think) Yes, he is definitely no longer in business. Sadly, he won't be posting anymore here either and is greatly missed. New username, same Pat Mac |
