Will's build #2, Bouzouki kit http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10134&t=39686 |
Author: | William Shafer III [ Tue Mar 12, 2013 12:20 pm ] |
Post subject: | Will's build #2, Bouzouki kit |
Better late then never right! I bought this kit from Music Makers late last year and was waiting to completly finish my first build before I start and I'm just about there now. This kit came with: Solid cherry spanish style neck Solid cherry sides Solid mahognay sound board Laminate cherry back Spruce braces Paduk brigde Indian rosewood fret board Black closed gear tuners Ironically I decided to do my first build from scratch. (I did a gourd mandolin, did it because I've done other gourd instruments) Guess I didn't want to mess up a $400 kit. ![]() Please let me know what you think of the woods. I'll post a pick of the kit ASAP. Thanks, Will |
Author: | Alex Kleon [ Tue Mar 12, 2013 12:45 pm ] |
Post subject: | Re: Will's build #2, Bouzouki kit |
The wood selection sounds great, Will! I'm really looking forward to seeing how this goes together. Do you have a set of plans that you can show us? Have fun! ![]() Alex |
Author: | William Shafer III [ Tue Mar 12, 2013 1:59 pm ] |
Yea it is a great wood selection. Here is a link to there site: http://www.harpkit.com/mm5/merchant.mvc ... =bouzoukis you can also look up some free PDF plans from this site too. Got a great set of trekker guitar plans for build #3. |
Author: | William Shafer III [ Tue Mar 12, 2013 9:45 pm ] |
Here is the kit I got from harpkit.com. The request I had was to have them leave the top intact (no sound hole cut) I'll be doing F holes. Also, I went to Stewmac and ordered mahogany reversed kerfing to replace the plywood kerfing they provided. I'll be putting in a transductive pick up in as well. They say it's a 20-30 hour build. |
Author: | Doug Balzer [ Tue Mar 12, 2013 9:51 pm ] |
Cool project Will. I will watch with great interest! |
Author: | William Shafer III [ Fri Mar 15, 2013 11:29 pm ] |
Yesterday when I went to glue the sides to the tail block I discovered that low and behold one side was 1/16" thicker then the other. ![]() Tonight I'm gluing the sides to the neck and starting to work on the kerfing! ![]() Been debating whether I'm gonna do purfling or not... originally I was not gonna for this build, but everyone has been raising the bar. Hmm, the bridge is padauk and i have some 1/8" padauk laying around. What do ya'll think? I'd have to do it all with hand tools. Should I? |
Author: | William Shafer III [ Sat Mar 16, 2013 12:28 pm ] |
So, gluing the kerfing is going pretty good so far. I discovered when I glued the sides that it cocks the neck to the side a bit. I was impressed though the instructions actually suggest that of this happens to use some small tacks on the overhang of the sound board to help hold the body square while gluing the top. ![]() ![]() |
Author: | William Shafer III [ Sun Mar 17, 2013 8:41 pm ] |
Been working on the bouzouki today. I'll probably start on the top and back very soon. |
Author: | William Shafer III [ Tue Mar 19, 2013 11:53 am ] |
So I finished bracing the back and sound board as instructed by the plans. They look pretty good, I'll post a picture tonight. I now have a bit of a conflict to resolve. ![]() Does anyone have experince with binding using chisels only? Should I just do f-holes? I really like the triangle sound holes... would it look wierd if I didn't do binding? |
Author: | WudWerkr [ Tue Mar 19, 2013 12:27 pm ] |
William Shafer III wrote: So I finished bracing the back and sound board as instructed by the plans. They look pretty good, I'll post a picture tonight. I now have a bit of a conflict to resolve. ![]() Does anyone have experince with binding using chisels only? Should I just do f-holes? I really like the triangle sound holes... would it look wierd if I didn't do binding? If your gonna Bind the sound hole , you just Bind the edge that is exposed , Or are you Talking about applying a rosette? |
Author: | William Shafer III [ Tue Mar 19, 2013 12:40 pm ] |
Author: | PeterF [ Tue Mar 19, 2013 5:39 pm ] |
I don't have a router either and I did both my rosettes by hand. In fact, it probably wouldn't apply to your build, but I think hand cutting makes it easier to do more interesting style rosettes. With a router it's so easy just to do a circle people tend not to do anything else, but by hand it's the same difficulty whether doing a circle or an odd shape. |
Author: | William Shafer III [ Thu Mar 21, 2013 12:12 pm ] |
Quote: I don't have a router either and I did both my rosettes by hand. In fact, it probably wouldn't apply to your build, but I think hand cutting makes it easier to do more interesting style rosettes. With a router it's so easy just to do a circle people tend not to do anything else, but by hand it's the same difficulty whether doing a circle or an odd shape. ![]() I decided that instead of doing a rosette for this build I would do binding instead. I was on www.liutaiomottola.com and he gives a really good tutorial on how to do it. Also, I decided to go with an "original" sound hole shape, it is a pentagon with rounded corners. Should be a bit of a challenge to bend the paduak! ![]() |
Author: | William Shafer III [ Thu Mar 28, 2013 11:09 pm ] |
Been busy with household things the past week, but I was able to finish reinforcing the sound hole and got a new hand tool for the shop. ...yes I know it looks like an inverted superman symbol, ![]() ![]() Oh well, I like how it looks. Hope to get it bound by the end of the week. |
