It is currently Sun Sep 14, 2025 10:54 am
PostPosted: Wed Feb 19, 2014 3:56 pm
First name: sean
State: nm
Zip/Postal Code: 88349
Country: us
I have repaired and glued up a few neck joints that were broke loose. Right now I find myself needing to pull a neck off an archtop silvertone from the late 50's that is still solid at the joint.
I have heard of pulling a fret, drilling a small hole, and steaming. Unfortunately, I have never seen it and I am not even sure where to start.
Whatever you do DON'T confuse me as an EXPERT, or MASTER, just a self learned trial and error guy. I had to build a dozen guitar before I found out what a "Luthier" even was (????)
PostPosted: Wed Feb 19, 2014 5:24 pm
Works great if you can cobble up some gear.
I used to have the needle to air up a basketball, some rubber tubing, and a tea pot.
I would think these days you could use one of those little hand-held Shark steam cleaners.
Just modify it a bit, and you're in business!
I also used a large hypodermic needle (veterinarian supply) full of boiling water and a drop of liquid soap.
You'll have to be careful, and clean up the mess as you go.
Be prepared to touch up the finish afterwards, either way you choose to go.
PostPosted: Thu Feb 20, 2014 8:04 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
If the archtop has a floating fret board you need to pull the heel cap and drill into the joint from there.
Brian
PostPosted: Thu Feb 20, 2014 9:52 am
First name: sean
State: nm
Country: us
Thanks for the replys, I will give it a shot, and if I run into problems I will be back here begging for help.
PostPosted: Fri Mar 28, 2014 12:11 pm
First name: Hamilton
Last Name: Perkins
City: Newport Beach
Zip/Postal Code: 92663
I use a very similar setup. This is the best way to do it. Just keep in mind, the more steam exposure to the glue the better its going to come apart.
PostPosted: Sun Mar 30, 2014 5:06 pm
First name: Michiyuki
Last Name: Kubo
State:
Country: Österreich
To add in, I saw a small device specifically designed to steam hats and coats. It was about 30-40€ and may be worth looking into if you do not have a steam producer already.
久保
美智え
