It is currently Sat Sep 13, 2025 3:55 pm
Post new topic Reply to topic  [ 52 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sat Apr 25, 2015 10:58 am
First name: Big
Last Name: Jim
Light Sanding on the back and introduced a Cherry stain . I believe it will look better with the Black top than the orig Tobacco Brown . If you look at sides closely you will see the Difference . Sides Next , then neck
PostPosted: Sun May 10, 2015 10:09 am
First name: Big
Last Name: Jim
Ok , thoughts on this question. I remounted the neck last night after fixing the Martin . The center line is off at bridge by .090 . The easy thing would be to put an oversized bridge on and adjust slightly. The Only reason I consider this is the neck fit looks factory to the body. Hate to mess with it. I am going to put a feeler Gage under and see how much I need . Thoughts ?
