It is currently Mon Sep 15, 2025 11:02 am
PostPosted: Thu Jan 12, 2017 12:36 pm
First name: Daniel
Last Name: Petrzelka
State: Washington
I'm going to be doing some drop filling and light finish repair on several instruments - 60's Gibson B-25 3/4, '69 D-35, late 60's D-28, and trying to decide which Nitro lacquer is most appropriate.
I will be doing some drop filling, and on the back of the D-35, I'll doing some airbrush work repairing some finish damage from a guitar stand that had a vinyl plastic pad touching the back of the body. (I'll do a post about that in a separate thread - buyer beware!)
Is Behlen or Seagrave your preferred nitro for repair/restoration work?
thank you for any suggestions
Daniel
PostPosted: Mon Jan 16, 2017 7:50 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I us neither actually, but for touch ups like you describe either should work equally well.
Brian
PostPosted: Fri Jan 27, 2017 2:07 am
So, Brian, what brand of nitrocellulose do you use?
michael propsom
www.propsomguitars.com
PostPosted: Fri Jan 27, 2017 10:45 am
First name: Daniel
State: Washington
I'm surprised that there are no key deciding factors between the two formulas - even Stew Mac tech's said they use either, but of course if pressed they go for the Seagrave, but no real articulation of why.
With a price difference of approximately 50%, and no real marketing behind either I have to believe there is at least some material/functional difference.
PostPosted: Fri Jan 27, 2017 9:46 pm
Last Name: Fields
City: Granite Falls
Zip/Postal Code: 28630
I'm partial to Behlen, but then again, I'm also biased. I'm good friends with the chief chemist at the company that makes it. [:Y:]
Mike Fields
PostPosted: Fri Feb 03, 2017 9:10 am
First name: Christopher
Last Name: Parker
City: Fatetteville
State: AR
Zip/Postal Code: 72701
FWIW, I think Seagrave is the same lacquer as what used to be called McFadden's. it's the brand Benedetto recommends in his book. I've used both for touchups and drop fills, and they each perform equally well. I've not sprayed Behlen lacquer, but I suspect it would perform as well as the McFadden/Seagrave.
These users thanked the author Christopher Parker for the post: dpetrzelka (Fri Feb 03, 2017 10:11 am)
PostPosted: Fri Feb 03, 2017 9:15 am
Not sure, but I believe Seagrave has more solids content than Mohawk/Behlen
These users thanked the author Haans for the post: dpetrzelka (Fri Feb 03, 2017 10:11 am)
PostPosted: Fri Feb 03, 2017 10:16 am
First name: Daniel
State: Washington
Higher solids seems like the better choice for drop filling - think I'll go with the Seagrave.
Thank you all.
PostPosted: Fri Feb 03, 2017 5:51 pm
For drop fills, doesn't much matter...pour some in a cap and let it dry for a few days. Usually took 12-14 coats of Mohawk and 7-9 coats of Seagrave for me.
