wax over shellac
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10137&t=42286
Author:  gxs [ Tue Dec 24, 2013 4:48 pm ]
Post subject:  wax over shellac
Does anyone have a favorite wax to recommend to put over a shellac finish? I want to put a final polish on a project. I have used McGuire's top coat safe before with some luck, but sometimes it clouds up. What do you use? Thanks,
GS
Author:  gxs [ Wed Dec 25, 2013 2:22 am ]
Post subject:  Re: wax over shellac
Thanks Filippo. Are you using 100% carnauba, or a blend?. The hardware down the street has a carnauba blend in the wood finish aisle, but there was other stuff in there I did not recognize.
GS
Filippo Morelli wrote:
Depends. Carnauba or Briwax does the trick.
Filippo
Author:  gxs [ Fri Dec 27, 2013 12:22 am ]
Fantastic, thanks. I'll look for it and give it a try.
GS
Carnauba can not be used at 100%. That's false marketing.
I use Zymol Carbon wax.
Filippo
Author:  B. Howard [ Fri Dec 27, 2013 9:20 am ]
I like Butchers Boston Polish, but any high quality furniture paste wax will do. Avoid bowling alley wax as it is not the right blend for this.
Author:  gxs [ Fri Jan 03, 2014 12:59 am ]
Thanks Brian, I'll look for that also.
GS
Author:  gxs [ Fri Jan 03, 2014 1:21 am ]
I found Johnson Wax general purpose paste did not work well for me, clouded up quickly. I also don't like that the JW doesn't say what is in it on the tin.
I also tried Howard's Feed -N- Wax, and while it was easy to work with I am not sure it left much of a wax coat over the shellac, which was already pretty shiny. Thanks guys, I'll pick up these products and give them a try.
GS
Author:  RTurner [ Fri Jan 03, 2014 5:10 pm ]
I keep meaning to get some Renaissance Wax...a "microcrystalline" wax originally developed for the British Museum. Suppose to be "da bomb".
