It is currently Sat Sep 13, 2025 12:02 pm
PostPosted: Fri Mar 22, 2013 8:39 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
Thanks for posting Todd. Looks great, always good to get another useful idea for the shop
Fred
Fred Tellier
PostPosted: Fri Mar 22, 2013 8:43 am
First name: Big
Last Name: Jim
Fred
+1 Thanks Todd ... Exactly what we Need in this Sub Forum [:Y:]
PostPosted: Mon Mar 25, 2013 11:32 pm
Good stuff; thank you.
PostPosted: Thu Mar 13, 2014 6:31 pm
Last Name: Killin
ARRRRGHHHHHH gaah gaah gaah gaah gaah
I miss the Todd content.
PostPosted: Thu Mar 13, 2014 7:32 pm
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
me too, I have a need for this one
PostPosted: Thu Mar 13, 2014 10:01 pm
First name: EddieLee
Last Name: Brown
It must be a time paradox. A time traveler must have disrupted the marriage of Todd's parents and he was never born. But.... the comments still remind.
_____________
EddieLee
PostPosted: Fri Mar 14, 2014 12:25 pm
First name: Ringo
I don't know what happened to Todd or his posts, but here's a couple of easy ways to do it with power tools. First, calculate the slope (rise over run) you need, then:
1. On the bandsaw or tablesaw, just attach a spacer to the board with tape in the proper location to give you the right slope like so:
run it through then clean up the resulting wedge on a sander or similar, or
2. If you have a thickness sander, attach the thin board that is to be the wedge to the top of a much thicker block with a little dab of glue, double sided tape, or as shown with a piece of paper glued between which makes it easy to separate the two later. Have it ride on a spacer in the appropriate spot, then run it through. I recently made some tapered Oud fretboards for someone this way and they came out perfect right out of the sander.
The key in both methods (and I'm sure there are lots of other ways to do the same) is to use a thick, flat piece of wood between spacer and wedge that is stiff enough to not deflect at all as the wedge is being milled.
edit to add: if you're using a bandsaw or table saw, be sure to use a zero clearance insert or something similar to keep the thin wedge from falling down through the throat plate!
Last edited by James Ringelspaugh on Fri Mar 14, 2014 2:57 pm, edited 1 time in total.
These users thanked the author James Ringelspaugh for the post: jack (Fri Mar 14, 2014 7:59 pm)
PostPosted: Fri Mar 14, 2014 2:10 pm
Last Name: Killin
Thanks James.
