Replacing nut on Ibanez Wizard III neck
http://w-ww.luthiersforum.com/forum/viewtopic.php?f=10137&t=44140
Author:  raorn [ Fri Sep 12, 2014 7:43 am ]
Post subject:  Replacing nut on Ibanez Wizard III neck
Greetings, luthiers.
I am about to replace nut on Ibanez XP300FX with 3pc Wizard III neck. Bought matching Graphtech Black Tusq XL 43x6mm nut, googled video instruction http://www.youtube.com/watch?v=tmUAuRs3Og0. Looks like it's not a Rocket Science - remove old nut, sand new nut, check strings height, glue new nut.
Are there any caveats? Any common mistakes? Is there anything Wizard-specific or Tusq-specific I should know before I start? Is it OK to use PVA glue, or I should use Epoxy?..
Author:  Cal Maier [ Fri Sep 12, 2014 9:33 am ]
Post subject:  Re: Replacing nut on Ibanez Wizard III neck
PVA is fine, do NOT use epoxy.
C~
Author:  dzsmith [ Fri Sep 12, 2014 5:36 pm ]
C~
And only a tad on the bottom of the nut.
I use two small dabs.
